problem with keypad library?
I have an arduino mega 2560 i just dowloaded the keypad library and open the first example ( custom keypad) the code is this:
/* @file CustomKeypad.pde
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Demonstrates changing the keypad size and key values.
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'0','1','2','3'},
  {'4','5','6','7'},
  {'8','9','A','B'},
  {'C','D','E','F'}
byte rowPins[ROWS] = {3, 2, 1, 0}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {7, 6, 5, 4}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
void loop(){
  char customKey = customKeypad.getKey();
  if (customKey != NO_KEY){
    Serial.println(customKey);
but when i compile the program i get this errors :
CustomKeypad:48: error: redefinition of ‘const byte ROWS’
CustomKeypad:11: error: ‘const byte ROWS’ previously defined here
CustomKeypad:49: error: redefinition of ‘const byte COLS’
CustomKeypad:12: error: ‘const byte COLS’ previously defined here
CustomKeypad:51: error: redefinition of ‘char hexaKeys [4][4]’
CustomKeypad:14: error: ‘char hexaKeys [4][4]’ previously defined here
CustomKeypad:57: error: redefinition of ‘byte rowPins [4]’
CustomKeypad:20: error: ‘byte rowPins [4]’ previously defined here
CustomKeypad:58: error: redefinition of ‘byte colPins [4]’
CustomKeypad:21: error: ‘byte colPins [4]’ previously defined here
CustomKeypad.cpp: In function ‘void setup()’:
CustomKeypad:63: error: redefinition of ‘void setup()’
CustomKeypad:26: error: ‘void setup()’ previously defined here
CustomKeypad.cpp: In function ‘void loop()’:
CustomKeypad:67: error: redefinition of ‘void loop()’
CustomKeypad:30: error: ‘void loop()’ previously defined here
Is anyone able to help me with that ! I am not that experienced with programming in C ! I am gessing there is something to do with syntax ??? but i am not so sure . PLZ HELP !
Moderator edit: CODE TAGS added. You may wish to give your keyboard a good shake - your “?” appears to be stuck down.
See this thread from yesterday: http://arduino.cc/forum/index.php/topic,90458.0.html
I posted my library link on that other thread. OP is welcome to use my library.
