Problem with LCD, KeyPad and CardReader
Hi, i am trying to create a security system with arduino and these three components: the LCD (16x2), the KeyPad (4x4) and the Card Reader.
The problem is that i can't understand why they wont work all in the same sketch.
I don't think that i wired them uncorectly because if i try to use them individually, they work perfectly.
Here's the code:
#include <LiquidCrystal.h> //include LCD library (standard library)
#include <Keypad.h> //include keypad library
#include <SPI.h>
#include <MFRC522.h>
#define redLED 10 //define the LED pins
#define greenLED 11
#define SS_Pin 10
#define RST_Pin 9
#define LED_G 4
#define LED_R 5
#define Buzzer 2
MFRC522 mfrc522(SS_Pin, RST_Pin);
char* password ="1234"; //create a password
int pozisyon = 0; //keypad position
const byte rows = 4; //number of the keypad's rows and columns
const byte cols = 4;
char keyMap [rows] [cols] = { //define the cymbols on the buttons of the keypad
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins [rows] = {1, 2, 3, 4}; //pins of the keypad
byte colPins [cols] = {5, 6, 7, 8};
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, rows, cols);
LiquidCrystal lcd (A0, A1, A2, A3, A4, A5); // pins of the LCD. (RS, E, D4, D5, D6, D7)
void setup(){
  lcd.begin(16, 2);
  pinMode(redLED, OUTPUT);  //set the LED as an output
  pinMode(greenLED, OUTPUT);
  setLocked (true); //state of the password
  SPI.begin();
  mfrc522.PCD_Init();
  pinMode(LED_G, OUTPUT);
  pinMode(LED_R, OUTPUT);
  pinMode(Buzzer, OUTPUT);
  Serial.println("Put your card to the reader...");
void loop(){
//KeyPad and LCD code
  char whichKey = myKeypad.getKey(); //define which key is pressed with getKey
  lcd.setCursor(0, 0);
  lcd.print("    Welcome");
  lcd.setCursor(0, 1);
  lcd.print(" Enter Password");
  if(whichKey == '*' || whichKey == '#' || whichKey == 'A' ||       //define invalid keys
  whichKey == 'B' || whichKey == 'C' || whichKey == 'D'){
    pozisyon=0;
    setLocked (true);
    lcd.clear();
    lcd.print("  Invalid Key!");
    lcd.clear();
  if(whichKey == password [pozisyon]){
    pozisyon ++;
  if(pozisyon == 4){
    setLocked (false);
    lcd.clear();
    lcd.print("*** Verified ***");
    delay(3000);
    lcd.clear();
    lcd.print("  Mert Arduino");
    lcd.print("Tutorial Project");
    delay(7000);
    lcd.clear();
  delay(100);
  //Card Reader Code
    if (!mfrc522.PICC_IsNewCardPresent()) {
    return;
  if (!mfrc522.PICC_ReadCardSerial()) {
    return;
  Serial.print("UID tag :");
  String content = "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(mfrc522.uid.uidByte[i], HEX);
    content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
    content.concat(String(mfrc522.uid.uidByte[i], HEX));
  Serial.print("Message : ");
  content.toUpperCase();
  if (content.substring(1) == "xx xx xx xx") { //string for the correct key
    Go();
    Deny();
void setLocked(int locked){
  if(locked){
    Deny();
    else{
      Go();
  void Go() {
  Serial.println("Go");
  delay(3000);
void Deny() {
  Serial.println("Deny");
  delay(3000);
If someone can help me i would apreciate that. :slight_smile:
You have pin conflicts between the keypad and LED_G and _R and the buzzer.
You are using the Serial port, pin 1 is the hardware serial TX pin. Another conflict.
I could recommend using an I2C enabled LCD, that would save 4 pins.
What does "won't work" mean? Can you describe what the code actually does and how that differs from what you want?
Thank you.
It means that when i try to use the reader it works correctly printing out in the serial monitor the correct string, but when i try to use the keypad anything in that part of the code work, like it's bypassed.
Also if i use the I2C Lcd it wouldn't save a digital pin (witch i need if i don't wonna use the TX 1)
And i don't think that the problem is the pin 1 because if i try to use this sketch that avoids to use the card reader it works correctly
#define greenLED 11
void setup(){
  lcd.begin(16, 2);
void loop(){
    pozisyon=0;
    setLocked (true);
    lcd.clear();
    lcd.clear();
    pozisyon ++;
  if(pozisyon == 4){
    setLocked (false);
    lcd.clear();
    delay(3000);
    lcd.clear();
    delay(7000);
    lcd.clear();
  delay(100);
  if(locked){
    digitalWrite(redLED, HIGH);
    digitalWrite(greenLED, LOW);
    else{
      digitalWrite(redLED, LOW);
      digitalWrite(greenLED, HIGH);
