problem with lcd.print and char variables on a QAPASS 16x2 I2C-LCD
So here is the new post.
If I print a string directly with lcd.print("somestring");, it works. But if I print a string via a variable, it displays just one character (as shown in the picture).
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
float temp;
bool HHein;
int tempPin = 0;
int HHeinPin = 2;
char HHeinOut;
hd44780_I2Cexp lcd;
  pinMode (2, INPUT);
  lcd.begin(16,2);
  HHein = LOW;
  temp = analogRead(tempPin);
  temp = temp * 0.02;
  //HHein = digitalRead(HHeinPin);
  HHein = LOW;
  if (HHein == HIGH){
    HHeinOut = "ein";
  else {
    HHeinOut = "aus";
  lcd.clear();
    lcd.setCursor (0,0);
    lcd.print("Boiler: ");
    lcd.print(temp);
    lcd.print(" C");
    lcd.setCursor (0,1);
    lcd.print("Heizung: ");
    lcd.print(HHeinOut);
The result is lcd1.jpg.
lcd2.jpg + lcd3.jpg are showing the lcd module.
If I use the LiquidCystal_I2C library, it shows a "&" with the same code.
If I use this code, it works (lcd4.jpg):
#include <Wire.h>
float temp;
bool HHein;
int tempPin = 0;
int HHeinPin = 2;
char HHeinOut;
hd44780_I2Cexp lcd;
  pinMode (2, INPUT);
  lcd.begin(16,2);
  HHein = LOW;
  temp = temp * 0.02;
  HHein = LOW;
  lcd.clear();
    lcd.print(temp);
    lcd.print(" C");
    if (HHein == HIGH){
      lcd.print("ein");
    else {
      lcd.print("aus");
    //lcd.print(HHeinOut);
Nadine
char HHeinOut;
HHeinOut is declared as a single character. It will not hold more than 1 character. If you want it to hold a string you need to declare it as a character array with enough room for all the characters and a terminating null ('\0').
char HHeinOut[6];  // a string (null terminated character array) with room for 5 characters and a null
HHeinOut = "ein";
Also you cannot use the = to assign the value like that. Use strcpy() instead.
You have a "QAPASS 16x2 I2C-LCD", that's why it works at all; it has QUuality check PASSed.
One of the many reported in this Forum Section. :slight_smile:
david_prentice answered this in the other thread.
https://forum.arduino.cc/index.php?topic=519666.msg4332773#msg4332773
I wouldn't use the solution that groundFungus proposed.
I'd use a pointer as david recommended.
Simply correct the declaration of HHeinOut
char *HHeinOut;
This creates a type of variable that allows it to the desired string.
Did you get a warning about this?
I would recommend that you enable all compiler warnings in the IDE settings.
Alternatively, you could do it inline without variable.
Ex:
    lcd.print(HHein ? "ein" : "aus");
This will print "ein" when HHein is true otherwise "aus"
--- bill
OK, thank you all, I made several stupid mistakes.
The stupidest of all was to not enlarge the message area at the bottom of the IDE. I verified the code every time and there where no errors or warnings in the two lines visible. Only if I enlarge this section, it shows several warnings. The message bar remained green so it looked like there's no problem.
bperrybap:
The compiler warning default setting is 'none'... Changed it to 'all' now.
That was another stupid one:
groundFungus:
char HHeinOut;
Got that, thank you.
bperrybap:
char *HHeinOut;
I did this and it worked, but it prompts this warning:
warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
     HHeinOut = "ein";
     HHeinOut = "aus";
If I change the variable to
char const *HHeinOut;
there are no warnings. It also works with
String HHeinOut;
Is it correct, that String xxx is the same as char *xxx ?
If so, I don't understand, why it should be wrong to assign a value to a string/char* with the '=':
groundFungus:
HHeinOut = "ein";
In the Examples - 08.Strings it's also assigned like that. Where's the mistake?
david_prentice:
You have several problems with your code.
bool HHein;      //true or false
char HHeinOut;    //should be a char*
  HHein = LOW;  //LOW happens to have the same value as false
if (HHein == HIGH){  //HIGH happens to have the same value as true
    HHeinOut = "ein";
  else {
    HHeinOut = "aus";
I thought because it only can have the value 1 or 0 it's good to use bool (and because it works). It should be
int HHein = 0;
correct?
Nadine
String HHeinOut;
There will be little difference for a const char* or const String
The bytes will be stored in PROGMEM. Probably as a NUL-terminated char array. Probably without the size member. (I have not inspected the generated ASM code)
A regular char* or String implies SRAM. Which is really WASTEFUL for an anonymous constant string. Especially when most Arduino classes will accept strings from PROGMEM.
I suggest that you use const char* instead of String. Your choice depends on whether subsequent calls expect String or char*. The Arduino print() will accept both String or char*
Regarding 0 and 1 versus false or true. C++ is not very strict. C is even less strict. Java would complain.
Personally, I would have chosen:
David.
Edit. Please do not take the above statements as Gospel. I must check exactly what and where the Compiler handles const char* and const char PROGMEM array[ ]
Not important for your project. But matters when there is a lot of anonymous data.
david_prentice:
I'd have to go look at the compiler output but I think this requires using the Arduino F() macro to get it not to use RAM on the AVR for holding the string data.
i.e.
lcd.print(HHein ? F("ein") : F("aus"));
I don't use AVRs much anymore so I tend to forget about its limitations.
--- bill
Thanks for your explanation, I haven't considered the memory at all. Now I've changed it to the inline statement, but it was interesting anyway and I learned from it.
Nadine
