Problem with ld1114v33 and MFRC522 RFID
I'm trying to make a separate power supply for MFRC522 RFID using lm7809 and ld1117v33 the power supply circuit will be supplied by 16v DC from an external testing supply and later on will be supplied by 12v DC ( my car battery ) , the problem now when I connect the circuit , the RFID takes 260mA and cuz the regulated to go over heated which I think is wrong cuz when I supply it from the arduino 3.3v port the regulator on the arduino board doesn't get over heated , I have 100nF capacitor at ld111v33 output
Does any one has a clue about what's wrong ?
Yes
You need to look at the data sheet for your device from your device manufacturer as to the minimum capacitance you need on the input AND the output of your regulator.
That is because the it is dissipating much less power. The power that is turned into heat is given by voltage across the regulator X the current through it.
You will need a heat sink.
First of all thanks for your reply , for the ld1117v33 or the other on of lm7809 both have 100nf at output as data sheet says, for heat sink I don't believe it will resolve the problem cuz that heat is really extreme and if I leave for a while it smel like burning, I think there is something else needs to be done in the circuit desig . Or something and how the RFID sinks 260mA while its max rate is 50mA already ???? And why the arduino board regulator doent get overheated while its passing same voltage and current which mean same powerso it supposed to produce the same heat
No the Arduino is not passing the same current at the same voltage. The Arduino regulator for 3V3 only has 5V - 3V3 across it so that is a lot less power.
Can you post a link to the data sheet that only shows a capacitor on the output, that is most unusual.
Does the RFID still work on 3V3? It sounds like you may have killed it.
Mfg datasheet http://www.st.com/web/en/resource/technical/document/datasheet/CD00000544.pdf
Needs cap on input and output, and 0.1uf on output is entirely insufficient.
The RFID works just fine , for the caps , I put only 10nF at output since the input comes from a 16V DC power supply so the input already rectified that's why I don't use caps on the regulators input, my main questions is why my custom regulator gets over heated while the arduino regulator doesn't sincethe RFID draws the same current and voltage ?????
That is no reason at all, you don't seem to understand what they do. They drop the impedance of the supply at the regulator and stop it from oscillating. Have you looked at the power supply line with a scope?
This is for the last time:-
While the voltage across the RFID reader is the same, the voltage across the regulator is not. In the Arduino you have 5V - 3V3 = 1.7V, in your home built regulator with 12V on the input you have 12-3.3 = 8.7V.
Now clearly 8.7V is bigger than 1.7V.
If your RFID reader takes 250mA ( how did you come to this figure? ) then the Arduino regulator is burning
1.7 * 0.25 = 0.425W
In your home built regulator you are burning
8.7 * 3.3 = 28.71 W
OK, now that I have understood the cause, I solved the peoblem, however my car battery is 12v and i want to supply 3.3v to the rfid so i made the following :
12v from battery => lm7809 => lm7806 => ld11133 ( which produce 3.3V)
I have installed the capictors according to the data sheets and anyway those regulators are not LDO so they wont oscillate easily, now I have a little bit of heat on the lm7806 since the cross voltage is 2.3v so do you think I can come up with a better design ?
Yes you could do a lot better simply using a switching regulator sometimes called a buck converter.
Regulators do not have to be LDO to oscillate. On a project I was on I once had to scrap several thousand pounds worth of set top boxes because some one in purchasing changed the manufacturer of a linear regulator and it oscillated because it did not have the minimum capacitor value recommended for that specific manufacturer.
