I can't make Firmata test (firmata_test.exe) work with my leonardo board.
I works fine with and Uno, but with the Leonardo, I try picking up any serial port number, but the switch don't appear!
I have updated the library from Download Firmata_v2.3.5.zip (Firmata) . I just copy pasted the files in the arduino folder...but it didn't solve the problem
What is talking to the Arduino? The Leonardo needs to have DTR enabled to get serial communications to work. I'm guessing that the PC doesn't set that flag.
I can do other basic operation (download etc...) with the board.
Thanks for your answer, but I have no idea what DTR is, I can't find relevant info on google
Then go to the Leonardo page, read what it says about the serial and then add the line it tells you on that page at the very start of setup. I might have the syntax wrong butit gives you the idea.
The proper ratio of answers to questions is 1.0 or higher. You have not achieved that target.
and what about the ratio of your sens of humor?
Grumpy_Mike:
thanks, I found:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
if you talk about the question "What is talking to the Arduino?", I answered "I can do other basic operation (download etc...) with the board"
it seems it's not the good answer, I probably miss understood
could you ask again please, and could be more "basic" in your speaking, I am french
thanks
Look at your Arduino. There is a USB cable attached to it. The other end goes somewhere. I'm guessing that it does not go to a chicken coop. I'm guessing that it does go to a PC.
I'm guessing that there is some application running on the PC that is trying, and failing, to use the firmata protocol to talk to the Arduino. What I am not able to do is guess what that application is. So, I'm asking you, and you are dancing around not answering that simple question.
Upgrade Arduino IDE (even could try Beta version), then open the code with the File > Examples > Firmata > StandardFirmata menu, and then upload it to your Leonardo.
at PaulS
Sure I am the one who don't want to solve the problem
first, I saw some ardware are found as arduino, but I can't diable them:
also, I tried a software to control the usb connexions,
but I couldn't enable or disable things, even as administrator
