For the typical rotary servos, a detach means the servo stops commanding the motor and doesn't hold the position, you can move it freely by hand. But for these ones, it doesn't work like that. Unless I ground the PWM pin in the servo, it will always hold the position. Ans sometimes, don't know why (maybe it's stuck at the end of the screw) the servo keeps feeding current until I realize it smeells toasted and then it's too late.
Any ideas on how to avoid that and stop wasting money?
The output of these servos is driven by the horn running along a threaded rod so no wonder that it holds its position when detached. It also probably explains why it sticks if driven too hard to the end of the threaded rod
When I say "by hand" I mean that if I rotate the big gear I can move forward and backward the knob, but it makes some resistance and goes back to its position even after a servo.detach().
After that, if it disconnect the signal pin from the servo and connect it to ground, I can repeat that operation without the servo making any resistance or moving back to the last given position. That's what I find strange.
Normally servos only fail like this (cooking themselves) if you prevent the output from moving, thus stalling the servo's motor. Sometimes its possible to command the position
past the hard-stops, which will have the same effect...
