Problem with LiquidCrystal_I2C library
I building a project which is well along using Arduino 1.0.1. I want to add a 20x4 LCD. The one I bought used an I2C connection.
A test sketch from the vendor would not compile error free, and I determined it's library is for Arduino 022. I have
searched the web for a library that works with 1.0.1. I found one from Yourduino at
http://arduino-info.wikispaces.com/LCD-Blue-I2C.
Using library labeled "LiquidCrystal_I2C Library for 20 character 4 line displays" which says on the page it is for 1.0.1.
And the sketch Example "Software Sketch for 4 line 20 character Displays", at bottom of page.
Arduino 1.0.1 gives this error
C:\Users\Jim\Documents\Arduino\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:
In member function 'void LiquidCrystal_I2C::expanderWrite(uint8_t)':
C:\Users\Jim\Documents\Arduino\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:261:
error: 'class TwoWire' has no member named 'write'
Does anyone how to fix this?
Jim
That library doesn't seam to be very happy on 1.0.1.
You could use the New LiquidCrystal library: https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home
You will need to configure the pinout for your LCD in the variable creation as indicated in the LiquidCrystal_I2C.h.
This library is compatible both for IDE 22 and IDE 1.0.1.
Thanks for responding "fm"! I changed the name of the liquid Crystal_I2C library and loaded the one you suggested. Ran an example, got this error:
C:\Users\Jim\Documents\Arduino\libraries\LiquidCrystal\I2CIO.cpp: In member function 'int I2CIO::begin(uint8_t)':
C:\Users\Jim\Documents\Arduino\libraries\LiquidCrystal\I2CIO.cpp:68: error: 'class TwoWire' has no member named 'read'
C:\Users\Jim\Documents\Arduino\libraries\LiquidCrystal\I2CIO.cpp: In member function 'uint8_t I2CIO::read()':
C:\Users\Jim\Documents\Arduino\libraries\LiquidCrystal\I2CIO.cpp:121: error: 'class TwoWire' has no member named 'read'
C:\Users\Jim\Documents\Arduino\libraries\LiquidCrystal\I2CIO.cpp: In member function 'int I2CIO::write(uint8_t)':
C:\Users\Jim\Documents\Arduino\libraries\LiquidCrystal\I2CIO.cpp:144: error: 'class TwoWire' has no member named 'write'
Still lost
Jim
