Hello
i am new in arduino and i have problem with
make Smart card based on Arduino uno
if any one help me
for start i have use this source
https://github.com/metalamin/KITT-Cat
it work with me it send ATR work fine
my problem
i want to add to this source if when i got data from RX i show it in HEX format
like here
if (mySerial.available()){
Serial.write(mySerial.read());
my code is
#include <SoftwareSerialPar.h>
#define ledPin 13 // LED
#define dataPin 8 // to IO pin
#define resetPin 2 // to Reset pin
SoftwareSerialPar mySerial(dataPin, dataPin); // same pin for RX and TX
const int bufferSize = 60;
int cardSpeed = 9600; // Initial speed = Frecuency / 372 in the case for a 4Mhz reader
int interByteDelay = 200; // Inter byte delay in microseconds
byte data[bufferSize];
int dataSize;
static byte ATR[18] = { 0x3B,0x30,0x90,0x10,0x50,0x82,0x60,0x18 };
void reset_change(){
pinMode(dataPin, OUTPUT);
PutBytes(ATR,sizeof(ATR));
pinMode(dataPin, INPUT_PULLUP);
void PutBytes(byte data[],int n){
for(uint16_t i=0; i < n; i++) {
delayMicroseconds(interByteDelay);
mySerial.write(data[i]);
// Open serial communications
Serial.setTimeout(1);
mySerial.begin(cardSpeed); // set the data rate for the SmartCard
attachInterrupt(digitalPinToInterrupt(resetPin),reset_change,RISING); //Interrupt for the ATR after the RESET
void loop() // run over and over
if (Serial.available()){
pinMode(dataPin, OUTPUT); //Change the Data pin to OUTPUT mode
dataSize=Serial.readBytes(data,bufferSize);
PutBytes(data,dataSize);
pinMode(dataPin, INPUT_PULLUP); //Change the Data pin to INPUT mode
