Problem with MCP4241
Hey everybody
I'm trying to use an MCP4241 digital potentiometer and running into an issue I haven't been able to solve. This particular device is a two pots in one package (datasheet here)
I've successfully been able to get P0 working without issue, but can't get P1 to change at all, it stays at 78 Kohm measured from wiper to ground.
Since I can get P0 to work, my connections should all be good for the SPI portion. I've got P1B (pin 5) grounded, P1A (pin 7) to VCC, same for P0, P0B grounded and P0A to VCC.
The relevant code is as follows:
In my library header file:
const static uint8_t ADR_WIPER0 = B00000000;
const static uint8_t ADR_WIPER1 = B00010000;
const static uint8_t CMD_INCREMENT = B00000100;
const static uint8_t CMD_DECREMENT = B00001000;
Those commands start at page 45.
In the cpp file:
void MCP4241::volumeUp() {
	uint8_t left = ADR_WIPER0 | CMD_INCREMENT;
	uint8_t right = ADR_WIPER1 | CMD_INCREMENT;
	SPI.beginTransaction(settings);
	digitalWrite(slave_select_pin, LOW);
	SPI.transfer(right);
	SPI.transfer(left);
	digitalWrite(slave_select_pin, HIGH);
	SPI.endTransaction();
According to the datasheet, page 48, "Continuous Commands" you can send multiple commands and as long as they're valid they'll be executed. I've also tried only sending one command at a time, while "left" works, "right" doesn't.
I've got two pots, a 104 (100K) and a 103 (10K) both showing the exact same problem. I'm hoping there is something simple in the command I've overlooked.
Any help is appreciated,
Eric
Have you tried separating the commands to prove that the P1 command is OK? Easy to do by commenting out the
line.
Divide and conquer with debugging.
Rob
I have seperatred.
   SPI.transfer(left);
works perfect, but
doesn't work at all
What are ADR_WIPER0 and ADR_WIPER1 defined as?
Best to show the entire code so we can see this stuff, unless it's to large.
Rob
They're in the first post, but here they are again.
I've stripped everything down to get to the absolute basics and, that is all the code that has anything to do with my problem.
I call mcp4241.volumeUp() and mcp4241.volumeDown() from other places, and the function gets called, and only the single side responds.
Just to include it, here's more
SPISettings settings(10000000, MSBFIRST, SPI_MODE3);
MCP4241::MCP4241(uint8_t slave_select_pin) {
	setup_ss(slave_select_pin);
void MCP4241::setup_ss(uint8_t slave_select_pin) {
	pinMode(slave_select_pin, OUTPUT);
	this->slave_select_pin = slave_select_pin;
	SPI.transfer(left);
void MCP4241::volumeDown() {
	uint8_t left = ADR_WIPER0 | CMD_DECREMENT;
	uint8_t right = ADR_WIPER1 | CMD_DECREMENT;
	SPI.transfer(left);
and the header
class MCP4241 {
public:
	MCP4241(uint8_t slave_select);
	void volumeDown();
	void volumeUp();
protected:
	uint8_t slave_select_pin;
	const static uint8_t CMD_READ = B00001100;
	const static uint8_t CMD_WRITE = B00000000;
	const static uint8_t ADR_VOLATILE = B00000000;
	const static uint8_t ADR_NON_VOLATILE = B00100000;
	const static uint8_t TCON_REGISTER = B01000000;
	const static uint8_t STATUS_REGISTER = B01010000;
	void setup_ss(uint8_t slave_select_pin);
