Hi!
I am trying to build a hexapod using Mega-2560. I want to use 18 servo motors. I downloaded and placed the MegaServo library in the libraries folder and when i try to run this testing code:
#include <MegaServo.h>
#define NBR_SERVOS 12 // the number of servos, up to 48 for Mega, 12 for other boards
#define FIRST_SERVO_PIN 2
MegaServo Servos[NBR_SERVOS] ; // max servos is 48 for mega, 12 for other boards
int pos = 0; // variable to store the servo position
int potPin = 0; // connect a pot to this pin.
for( int i =0; i < NBR_SERVOS; i++)
Servos[i].attach( FIRST_SERVO_PIN +i, 800, 2200);
pos = analogRead(potPin); // read a value from 0 to 1023
for( int i =0; i <NBR_SERVOS; i++)
Servos[i].write( map(pos, 0,1023,0,180));
delay(15);
I am receiving the following errors:
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp: In function ‘void handle_interrupts(servoTimer_t, volatile uint16_t*, volatile uint16_t*)’:
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:96: error: ‘LOW’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:96: error: ‘digitalWrite’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:103: error: ‘HIGH’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:103: error: ‘digitalWrite’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:107: error: ‘clockCyclesPerMicrosecond’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp: At global scope:
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:169: error: ‘boolean’ does not name a type
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp: In constructor ‘MegaServo::MegaServo()’:
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:205: error: ‘clockCyclesPerMicrosecond’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp: In member function ‘uint8_t MegaServo::attach(int, int, int)’:
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:219: error: ‘OUTPUT’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:219: error: ‘pinMode’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:226: error: ‘isTimerActive’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp: In member function ‘void MegaServo::write(int)’:
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:247: error: ‘byte’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:247: error: expected `;' before ‘channel’
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:248: error: ‘channel’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:251: error: ‘map’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:258: error: ‘clockCyclesPerMicrosecond’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp: In member function ‘int MegaServo::read()’:
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:273: error: ‘map’ was not declared in this scope
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp: In member function ‘int MegaServo::readMicroseconds()’:
/home/sadanarshad/Downloads/arduino-1.0.5/libraries/MegaServo/MegaServo.cpp:280: error: ‘clockCyclesPerMicrosecond’ was not declared in this scope
