Problem with method= post
Hello, when I use de examples (Ethernet-webserver).
while (client.connected()) { if (client.available()) { char c = client.read(); Serial.write(c);
If i use method=Post to program a login page, de post don't apear. Someone can help ? Thanks.
morais123: If i use method=Post to program a login page, de post don't apear. Someone can help ?
If you just want to "program a login page", you surely do not use "Post" to prevent unauthorized persons from using your Arduino webserver.
Instead you programm a HTTP Basic access authentication for your webserver using the "HTTP 401 Not Authorized response code" if the user cannot authenticate himself with a valid username/password.
Please let me know if you need some webserver example code doing that.
