PROBLEM WITH MLX10407 CLUSTER AND SEVEN SEGMENT
hello to all
i am new here so forgive me if i make mistakes
any way i have an arduino uno,a seven segment display,a real instrument cluster and i want;
with the x simuator software to control the cluster(speed and tacho,with the MLX10407 DRIVE GAUGE if this is pausible) and for gears i want to use the seven segment display
the cluster is from a KIA CEED it has 4 pins(two coils)
I have connect the seven seg to the 74hc595 it works when i put this code
http://www.sweeting.org/mark/blog/2011/11/27/arduino-74hc595-shift-register-and-a-7-segment-led-display
that means i have connect it right, but i dont know how to connect th MLX10407 to arduino here is the datasheet photo
http://www.google.gr/imgres?imgurl=http://circuits.datasheetdir.com/67/MLX10407-circuits.jpg&imgrefurl=http://www.datasheetdir.com/MLX10407%2BPower-Drivers&h=360&w=540&sz=34&tbnid=KpypbFizs1BpEM:&tbnh=77&tbnw=115&zoom=1&usg=__f5elGMctIzTcADZ6u9lgtR4MiKE=&docid=BEgaNculgcpVEM&sa=X&ei=Zj1wUcGHBMXrsgaI0oGgCw&ved=0CD4Q9QEwAg&dur=399
thank you
