Hi guys,
the first, I'm sorry my English.
I am trying to do a small personal project that I hope will help me learn. I'm a bit of a rookie with arduino and ESP8266 but with Arduino I've already made some small things.
My project at the moment I am mounting it with a nodemcu, I have used this example as a base (http://www.sinaptec.alomar.com.ar/2017/06/tutorial-7-esp8266-guardar-ssid-y.html) , the example works for me correctly.
The base code has been modified for my requirements, at the moment I compile it and upload it correctly to the nodemcu, but when I put it in AP mode, the Wi-Fi network appears but I can not connect and sometimes I am connected but I do not have access to 192.168.4.1.
My code:
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
//-------------------VARIABLES GLOBALES--------------------------
struct configuracion_t {
char hostName[11]="h";
char ssidName[11]="srrrr";
char ssid_password[16]="123456789";
char ap_password[17]="ap";
boolean dhcp = true;
char ip_lan[16]="i";
char mask_lan[16]="255.255.255.0";
char gateway_lan[16]="g";
char api_user[101]="au";
char api_password[51]="app";
char api_device_id[33]="S";
} cfg;
int contconexion = 0;
unsigned long previousMillis = 0;
char ssid[50];
char pass[50];
char *ssid="ssid";
char *pass="pass";
const char *ssidConf = "SB_";
const char *hostConf = "SBH_";
const char *passConf = "123456789";
const char pVez='1';
String hostName="";
String ssidName="";
String mensaje = "";
char primeraVez;
//-----------CODIGO HTML PAGINA DE CONFIGURACION---------------
String pagina = "<codigo de la página html, esta en el fichero>";
String paginafin = "</body></html>";
//------------------------SETUP WIFI-----------------------------
void setup_wifi() {
// Conexión WIFI
WiFi.mode(WIFI_STA); //para que no inicie el SoftAP en el modo normal
Serial.println("* Nombre:");
Serial.println(ssid);
Serial.println("* Password");
Serial.println(pass);
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED and contconexion <50) { //Cuenta hasta 50 si no se puede conectar lo cancela
++contconexion;
delay(250);
Serial.print(".");
//digitalWrite(13, HIGH);
//delay(250);
//digitalWrite(13, LOW);
if (contconexion <50) {
Serial.println("");
Serial.println("WiFi conectado");
else {
Serial.println("");
Serial.println("Error de conexion");
WiFiClient espClient;
ESP8266WebServer server(80);
//-------------------PAGINA DE CONFIGURACION--------------------
void paginaconf() {
server.send(200, "text/html", pagina + paginafin);
//--------------------MODO_CONFIGURACION------------------------
void modoconf() {
delay(100);
delay(100);
delay(100);
delay(100);
WiFi.softAP(ssidConf, passConf);
IPAddress myIP = WiFi.softAPIP();
Serial.print("IP del acces point: ");
Serial.println(myIP);
Serial.print("Ssid: " );
Serial.println(ssidConf);
Serial.print("Password: " );
Serial.println(passConf);
Serial.println("WebServer iniciado...");
server.on("/", paginaconf); //esta es la pagina de configuracion
server.on("/guardar_conf", guardar_conf); //Graba en la eeprom la configuracion
server.on("/escanear", escanear); //Escanean las redes wifi disponibles
server.begin();
while (true) {
server.handleClient();
//---------------------GUARDAR CONFIGURACION-------------------------
void guardar_conf() {
Serial.println(server.arg("ssid"));//Recibimos los valores que envia por GET el formulario web
grabar(0,server.arg("name_ssid"));
Serial.println(server.arg("pass_wifi1"));
grabar(50,server.arg("pass_wifi1"));
mensaje = "Configuracion Guardada...";
paginaconf();
void leerConfiguracion(){
primeraVez = (char)EEPROM.read(0);;
Serial.print("primeraVez: ");
Serial.println(primeraVez);
if (primeraVez != pVez){
Serial.println("Es la primera vez que se ejecuta, se crea la configuración");
EEPROM.write(0, pVez);
//Calculamos el nombre y ssid del dispositivo
//y añadimos a la configuración.
Serial.print("El nombre del ESP es: ");
Serial.println(WiFi.hostname());
ssidName=WiFi.hostname().c_str();
hostName=WiFi.hostname().c_str();
Serial.print("Lo almacenado en hostname es ");
Serial.println(hostName);
ssidName.replace("ESP_",ssidConf);
hostName.replace("ESP_",hostConf);
Serial.print("El nuevo nombre ssid es");
Serial.println(ssidName);
Serial.print("El nuevo nombre del host es");
EEPROM.put(sizeof(pVez)+1,cfg);
EEPROM.commit();
} else{
Serial.println("Ya existe configuración");
Serial.println(sizeof(pVez));
EEPROM.get(sizeof(pVez)+1,cfg);
Serial.print("ssid Name: ");
Serial.println(cfg.ssidName);
Serial.print("Host Name: ");
Serial.println(cfg.hostName);
Serial.print("Password ssid: ");
Serial.println(cfg.ssid_password);
Serial.print("Mask Network: ");
Serial.println(cfg.mask_lan);
Serial.print("DHCP: ");
Serial.println(cfg.dhcp);
Serial.println("**HostName: "+WiFi.hostname());
void grabarConfiguracion(){
EEPROM.put(1,cfg);
EEPROM.commit();
//----------------Función para grabar en la EEPROM-------------------
void grabar(int addr, String a) {
int tamano = a.length();
char inchar[50];
a.toCharArray(inchar, tamano+1);
for (int i = 0; i < tamano; i++) {
EEPROM.write(addr+i, inchar[i]);
for (int i = tamano; i < 50; i++) {
EEPROM.write(addr+i, 255);
EEPROM.commit();
//-----------------Función para leer la EEPROM------------------------
String leer(int addr) {
byte lectura;
String strlectura;
for (int i = addr; i < addr+50; i++) {
lectura = EEPROM.read(i);
if (lectura != 255) {
strlectura += (char)lectura;
return strlectura;
//---------------------------ESCANEAR----------------------------
void escanear() {
int n = WiFi.scanNetworks(); //devuelve el número de redes encontradas
Serial.println("escaneo terminado");
if (n == 0) { //si no encuentra ninguna red
Serial.println("no se encontraron redes");
mensaje = "no se encontraron redes";
Serial.print(n);
Serial.println(" redes encontradas");
mensaje = "";
for (int i = 0; i < n; ++i)
// agrega al STRING "mensaje" la información de las redes encontradas
mensaje = (mensaje) + "<p>" + String(i + 1) + ": " + WiFi.SSID(i) + " (" + WiFi.RSSI(i) + ") Ch: " + WiFi.channel(i) + " Enc: " + WiFi.encryptionType(i) + " </p>\r\n";
//WiFi.encryptionType 5:WEP 2:WPA/PSK 4:WPA2/PSK 7:open network 8:WPA/WPA2/PSK
delay(10);
Serial.println(mensaje);
paginaconf();
//------------------------SETUP-----------------------------
pinMode(13, OUTPUT); // D7
pinMode(14, INPUT); //D5
// Inicia Serial
Serial.println("");
//Iniciamos la EEPROM para acceso a ella.
EEPROM.begin(512);
//Cargamos la configuración
leerConfiguracion();
if (digitalRead(14) == 0) {
Serial.println("boton pulsado");
modoconf();
ssid="hola";
pass="hola";
setup_wifi();
//--------------------------LOOP--------------------------------
if (currentMillis - previousMillis >= 5000) { //envia la temperatura cada 5 segundos
Serial.println("Funcionado...");
What am I doing wrong? I have searched the internet but I do not see or find anything concrete to my problem.
P.D .: Forgive if the code is a bit "dirty". The complete code I have attached to this post.
firmware.ino (14.5 KB)
