Hi ... I hope that you are good.
I want to monitor the battery voltages wirelessly when running the motors through COMPUTER (Perfectly runs0 and JOYSTICK (issues).
I'm using a DPDT switch when I switch it to the COMPUTER side for running the motors, it gives me a perfect result but when I switched it towards JOYSTICK side then sometimes motors run without any voltages reading and sometimes when it gives voltages reading then the motors could not be run.
I m using a DP-15 pin for my radio-link transmitter and DP-9 female connector to connect it with PC to monitor voltages ...
Here is the circuit diagram ...
I will be very thankful to you ...
