Problem with MPU-6050 code
#include <Wire.h>
#include <LiquidCrystal_I2C.h>          //Liraries for LCD display
#include <SoftI2C.h>
#define button 4
const int MPU_addr=0x68;  // I2C address of the MPU-6050
int AcX,AcY,AcZ;
const int trigPin = 3;
const int echoPin = 2;    //Digital pin input value
float count_shot = 0;
float made_shot = 0;
float field_pct = 0;
int button_pos = 0;
float toll = 0.05;
float normal_z = 0;
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
// LiquidCrystal_I2C lcd(0x27, 20, 4);
SoftI2C SoftWire = SoftI2C(6,7); // SDA, SCL
void setup(){
  Wire.begin();
  SoftWire.begin();
  SoftWire.beginTransmission(MPU_addr);
  SoftWire.write(0x6B);  // PWR_MGMT_1 register
  SoftWire.write(0);     // set to zero (wakes up the MPU-6050)
  SoftWire.endTransmission(true);
  pinMode(button, INPUT);
  pinMode(trigPin, OUTPUT); //Ultrasonic Pins
  pinMode(echoPin, INPUT);
  lcd.begin(20, 4);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Shot Tracker");
  lcd.setCursor(0, 1);
  lcd.print("Field Goal:");   //LCD Print
  lcd.setCursor(0, 2);
  lcd.print(made_shot, 0);
  lcd.setCursor(1, 2);
  lcd.print("-");
  lcd.setCursor(2, 2);
  lcd.print(count_shot, 0);
void loop(){
  for(int ind = 0; ind < 5; ind++) {
    SoftWire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
    SoftWire.endTransmission(false);
    SoftWire.requestFrom(MPU_addr,14,true);  // request a total of 14 registers
    AcX=SoftWire.read()<<8|SoftWire.read();  // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
    AcY=SoftWire.read()<<8|SoftWire.read();  // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)         //X, Y, Z output realing calculations
    AcZ=SoftWire.read()<<8|SoftWire.read();
    float normal_z = float(AcZ/16384);
  float ac_x = float(AcX/16384);
  float ac_y = float(AcY/16384);
  float ac_z = float(AcZ/16384);
  double duration, distance;
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(12);
  digitalWrite(trigPin, LOW);          //Inputs on Ultrasonic distance sensor
  duration=pulseIn(echoPin, HIGH);
  double dist = (duration/2.0/29.1);         //Calculation for distance
  if (dist < 22 or ac_z < (normal_z - toll) or ac_z > (normal_z + toll)) {
    count_shot += 1;
    if (dist < 22) {
      made_shot += 1;
      delay(2000);
      bool flag = 0;
      double time1 = millis();
      double time_diff = 0;
      while (flag == 0 and time_diff <= 2000) {
        if (dist < 22) {
          made_shot += 1;            //Calculation for whether shot actually went into hoop
          flag = 1;
          delay(2000 - time_diff);
        double time2 = millis();
        time_diff = time2 - time1;
//      int extra_time = 2000 - time_diff;
//      delay(extra_time);
//    Serial.print("Field Goal: ");
//    Serial.print(made_shot);
//    Serial.print(" / ");
//    Serial.println(count_shot);
//    delay(1000);
    if(count_shot > 0) {
      field_pct = made_shot / count_shot * 100;      //Field Goal % Calculation
      field_pct = 0;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Shot Tracker");        //LCD display intially
    if(made_shot < 10) {
      lcd.print("-");
    } else if(made_shot < 100 and made_shot >= 10) {
      lcd.print("-");
      lcd.setCursor(3, 2);                                       //LCD Print field goals made / attempted
      lcd.print("-");
      lcd.setCursor(4, 2);
    lcd.setCursor(19, 2);
    lcd.print("%");                                    //LCD print % sign for field goal percentage
    lcd.setCursor(14, 2);
    lcd.print(field_pct, 1);
  //field goal percentage logic
//  Serial.println(field_pct);
  //lcd code
//  LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
  //reset button code
  button_pos = digitalRead(button);
  if(button_pos == 1) {
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("RESET");
    made_shot = 0;
    count_shot = 0;
    field_pct = 0;
    delay(2000);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Shot Tracker");                //LCD print for if reset button is pressed
    lcd.print("-");
The code should work like this The way it's supposed to work:
count_shot is incremented if-
The ball hits the hoop and goes through
The ball hits the hoop and doesn't go through
The ball goes through without hitting the hoop (swish)
shot_made is incremented if-
The ball goes through and hit the hoop
I have a problem where the ball hits a hoop and it misses and its not counted as a miss for the field goal percentage + when i touch it it counts as a score.
The HC-SR04 can not tell your finger from a ball going through the hoop or the net moving or being perfectly still. It measures returning sound waves sent out in a 15 degree cone to hit whatever is in its path. [edit] The MPU6050 is probably feeling all the movement, too, "scoring" every bump.
