Problem with multiple functions
Hello, noob here...I have hacked together some of the example code with a small amount of success. I can individually get the functionality I want but when I put it together (obviously incorrectly) I get bad results.
I am trying to control the following:
Ping sensor
servo to rotate the Ping
steering servo
Novak ESC
You can probably guess what I'm trying to do. Here is my code so far.
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
int pos = 0;
int pingPin = 6;   // Ping Pin
const int ledPin = 13;  // On-board LED
 pinMode (ledPin, OUTPUT);
 myservo1.attach(3); // Steering Servo
 myservo2.attach(5); // ESC Output Pin
 myservo3.attach(9); // Ping Servo
void loop()// run over and over again
   myservo2.writeMicroseconds(1490); //  PWM to ESC...adjust this number between 1475 and 2100 for speed
  for(pos = 50; pos < 110; pos += 1)  // goes from 50 degrees to 110 degrees
  {                                  // in steps of 1 degree
    myservo3.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 110; pos>=50; pos-=1)     // goes from 110 degrees to 50 degrees
 long duration, inches, cm;
 // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
 // We give a short LOW pulse beforehand to ensure a clean HIGH pulse.
 pinMode(pingPin, OUTPUT);
 digitalWrite(pingPin, LOW);
 delayMicroseconds(2);
 digitalWrite(pingPin, HIGH);
 delayMicroseconds(5);
 // The same pin is used to read the signal from the PING))): a HIGH
 // pulse whose duration is the time (in microseconds) from the sending
 // of the ping to the reception of its echo off of an object.
 pinMode(pingPin, INPUT);
 duration = pulseIn(pingPin, HIGH);
 // convert the time into a distance
 inches = microsecondsToInches(duration);
 cm = microsecondsToCentimeters(duration);
 Serial.print(inches);
 Serial.print("in, ");
 Serial.print(cm);
 Serial.print("cm");
 delay(100);
 if (inches >= 24) {             // Distance to trigger Left Steer
   digitalWrite (ledPin, HIGH);
   pos=90;                       // Steer Straight
   myservo1.write(pos);
 else {
   digitalWrite (ledPin, LOW);
   pos=135;                      // Steer Left
long microsecondsToInches(long microseconds)
 // According to Parallax's datasheet for the PING))), there are
 // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
 // second).  This gives the distance travelled by the ping, outbound
 // and return, so we divide by 2 to get the distance of the obstacle.
 // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
 return microseconds / 73.746 / 2;
long microsecondsToCentimeters(long microseconds)
 // The speed of sound is 340 m/s or 29 microseconds per centimeter.
 // The ping travels out and back, so to find the distance of the
 // object we take half of the distance travelled.
 return microseconds / 29 / 2;
I know it's crude but I'm learning.
The problem is the Ping only "pings" as it turns the Ping Servo to the 50 degree posistion (instead of it's normal 10 times a sec). I'm sure it has to do with the brackets or formatting.
Eventually I want the steering servo to turn the oposite direction of a detected object. I haven't gotten that sophisticated yet.
Any help or suggestions are appreciated.
I'd break it down a bit further - put the whole of the Ping code into a separate function that just returns the range in the units you want:
#define INCHES 1
#define CM       0
long ranger (int units)
long duration;
 return (units == INCHES) ? microsecondsToInches(duration) : microsecondsToCentimeters(duration);
You can easily lose a lot of braces.
  { <- NOT NEEDED
  } <- NOT NEEDED
Once you've done that, you can start seeing where you're going wrong.
(Hint: You're not reading the Ping when you're moving myservo3)
