Problem with multiplexer (TCA9548A )
I am currently working on a student project, where I want to measure the airpreassure along with the airquality.
I have a SDP610 and a BME680.
The SDP610 is fully functional with my code but I have a problem to get the BME680 working correctly.
My circuit is working so it should be a coding problem.
Thank you for your time :slight_smile:
bme680_sdp610_neu.ino (6.88 KB)
Sensirion_Differential_Pressure_Sensors_SDP600Seri-1511233.pdf (464 KB)
tca9548a.pdf (1.16 MB)
In order to make sense of any code we need to see a schematic of your setup. Not a Fritzing physical layout but a real schematic.
Have you or someone else you know asked about this recently. It sounds like this is a class assignment.
Please read this:-
How to use this forum it will tell you haow to ask a question round here.
Grumpy_Mike:
That was this thread about connecting multiple 128x64 oled displays. But sensors were also mentioned in that thread, so not impossible this is a class assignment.
Needhelp1234:
One of each sensor? Why do you need a multiplexer? The two sensors have different addresses (0x76 or 0x77 for bme280 and 0x81 (or 0x40 in 7-bit?) for spd610), so I see no need for a multiplexer.
