int analogInPin = A0;
int buzzerPin = 8;
pinMode (buzzerPin,OUTPUT);// set buzzer as an output
pinMode (analogInPin,INPUT);//set ph sensor as an input
Serial.begin(9600);//start serial port at 9600 bauds
int sensor =analogRead(A5); // read the ph sensor
Serial.println (A5);// print the value of the ph sensor to the serial monitor
if ((A5 < 6.5) && (A5 > 9.0)) {
digitalWrite(8,HIGH); // if the ph sensor senses too low or too high ph level, turn the buzzer on
tone (8, 5000);
else ((A5 > 6.6)); {
digitalWrite (8,LOW);// if the ph sensor senses normal ph level, turn the buzzer off
tone (8, 0);
if ((A5 < 6.5) &
A5 has the value 19, on a Uno,IIRC
else ((A5 > 6.6));
Oops
int sensor =analogRead(A5); // read the ph sensor into a variable called sensor
Serial.println (sensor);// print the value of the sensor variable to the serial monitor
Hope this helps
