Problem with my Datalogger(SD) and DHT11
Hello,
recently I created a project with a friend, and we wanted to save Data on a SD Card which we got from the DHT11. We noticed that because of the dht.read...() method our Datalogger is unable to save anything.
#include <DHT.h>
//#include <DHT_U.h>
#include <Elegoo_GFX.h>    // Core graphics library
#include <Elegoo_TFTLCD.h> // Hardware-specific library
#include <TouchScreen.h>
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
//#include <String>
DHT dht(13, DHT11);
RTC_DS1307 rtc;
#if defined(__SAM3X8E__)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
#define YP A3  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 9   // can be a digital pin
#define XP 8   // can be a digital pin
#define TS_MINX 120
#define TS_MAXX 900
#define TS_MINY 70
#define TS_MAXY 920
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define LCD_RESET A4
#define MINPRESSURE 10
#define MAXPRESSURE 1000
// Assign human-readable names to some common 16-bit color values:
#define RED     0xF800
#define GREEN   0x07E0
#define BLUE    0x001F
#define WHITE   0xFFFF
#define BLACK   0x0000
Elegoo_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
File myFile;
unsigned long previousMillis = 0;
unsigned long shitypreviousMillis = 0;
const long interval = 5000;
const long shityinterval = 10000;
boolean druck = false;
boolean druck2 = false;
float temp = 2;
float humi = 1;
int zahl = 0;
void setup(void)
 dht.begin();
 rtc.begin();
 tft.reset();
 //pinMode(10, OUTPUT);
 identifier();
 tft.setRotation(3);
 tft.fillScreen(GREEN);
 //Jahr,Monat,Tag,Stunde,Minute,Sekunde
 rtc.adjust(DateTime(2020, 6, 4, 8, 46, 0));
 Serial.println("Initializing SD card...");
 if (!SD.begin())
   Serial.println("Card error");
   return;
 Serial.println("Card initialized");
 if (! rtc.begin())
   Serial.println("No RTC found");
   Serial.println("RTC clock found");
 if (! rtc.isrunning())
   Serial.println("RTC not configured");
 tft.fillScreen(RED);
 humi = dht.readHumidity();
 temp = dht.readTemperature();
 //  tft.fillScreen(BLACK);
 TSPoint p = ts.getPoint();
 // if sharing pins, you'll need to fix the directions of the touchscreen pins
 //  pinMode(XP, OUTPUT);
 pinMode(XM, OUTPUT);
 pinMode(YP, OUTPUT);
 //  pinMode(YM, OUTPUT);
 if (currentMillis - previousMillis >= interval)
   writeData(getTime() + ", " + "Temp: " + temp + "  Humidity: " + humi + "%");
 if ((druck == true))
   if ((druck2 == true))
     //getValue();
     anzeigen();
     Serial.println("Bildschirm on ");
     druck2 = false;
   if ((currentMillis - shitypreviousMillis) >= shityinterval)
     tft.fillScreen(BLUE);
     Serial.println("Bildschirm off ");
     druck = false;
 if (p.z > MINPRESSURE && p.z < MAXPRESSURE)
   // scale from 0->1023 to tft.width
   p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
   //    p.x = tft.width()-map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
   p.y = (tft.height() - map(p.y, TS_MINY, TS_MAXY, tft.height(), 0));
   //    p.y = map(p.y, TS_MINY, TS_MAXY, tft.height(), 0);
   Serial.print("( x=");
   Serial.print(p.x);
   Serial.print(" , y=");
   Serial.print(p.y);
   Serial.println(" )");
   druck = true;
   druck2 = true;
   shitypreviousMillis = currentMillis;
void anzeigen()
 tft.setCursor(60, 80);
 tft.setTextColor(WHITE);
 tft.setTextSize(5);
 tft.print(temp);
 tft.print(" C");
 tft.setCursor(60, 120);
 tft.print(humi);
 tft.println(" %");
 Serial.print(temp);
 Serial.println("C");
//String getValue() {
//temp = 40;
//humi = 40;
//humi = dht.readHumidity();
//temp = dht.readTemperature();
//Serial.print(humi);
//Serial.print(temp);
//String text = String("Temp: ") + dht.readTemperature() + "  Humidity: " + dht.readHumidity() + "%";
//return (text);
String getTime()
 DateTime now = rtc.now();
 String timeString;
 if (now.day() <= 9)
   timeString = "0";
   timeString += now.day();
   timeString = now.day();
 timeString += ".";
 if (now.month() <= 9)
   timeString += "0";
   timeString += now.month();
 timeString += ".";
 if (now.year() <= 9)
   timeString += "0";
   timeString += now.year();
 timeString += ", ";
 if (now.hour() <= 9)
   timeString += "0";
   timeString += now.hour();
 timeString += ":";
 if (now.minute() <= 9)
   timeString += "0";
   timeString += now.minute();
 timeString += ":";
 if (now.second() <= 9)
   timeString += "0";
   timeString += now.second();
 return timeString;
void writeData(String writetext)
 myFile = SD.open("test.txt", FILE_WRITE);
 if (myFile)
   myFile.println(writetext);
   myFile.close();
   zahl++;
   Serial.print(zahl);
   Serial.print("            ");
   Serial.println(writetext);
   myFile.println("fehler");
   myFile.close();
   Serial.print(myFile);
   Serial.print("Error, could not create/write file ( ");
   Serial.print(writetext);
   return;
void identifier()
 uint16_t identifier = tft.readID();
 if (identifier == 0x9325)
   Serial.println(F("Found ILI9325 LCD driver"));
 else if (identifier == 0x9328)
   Serial.println(F("Found ILI9328 LCD driver"));
 else if (identifier == 0x4535)
   Serial.println(F("Found LGDP4535 LCD driver"));
 else if (identifier == 0x7575)
   Serial.println(F("Found HX8347G LCD driver"));
 else if (identifier == 0x9341)
   Serial.println(F("Found ILI9341 LCD driver"));
 else if (identifier == 0x8357)
   Serial.println(F("Found HX8357D LCD driver"));
 else if (identifier == 0x0101)
   identifier = 0x9341;
   Serial.println(F("Found 0x9341 LCD driver"));
   Serial.print(F("Unknown LCD driver chip: "));
   Serial.println(identifier, HEX);
   //    Serial.println(F("If using the Elegoo 2.8\" TFT Arduino shield, the line:"));
   //    Serial.println(F("  #define USE_Elegoo_SHIELD_PINOUT"));
   //    Serial.println(F("should appear in the library header (Elegoo_TFT.h)."));
   //    Serial.println(F("If using the breakout board, it should NOT be #defined!"));
   //    Serial.println(F("Also if using the breakout, double-check that all wiring"));
   //    Serial.println(F("matches the tutorial."));
 tft.begin(identifier);
Arduino_Uno(doesnotworkbutitshould).ino (6.75 KB)
The code Auto formatted in the IDE and posted here in code tags in the preferred manner
miroslaw1 please take note
#include <DHT.h>
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
//#include <String>
DHT dht(13, DHT11);
RTC_DS1307 rtc;
#endif
#define TS_MINX 120
#define TS_MAXX 900
#define TS_MINY 70
#define TS_MAXY 920
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define RED     0xF800
#define BLUE    0x001F
File myFile;
float temp = 2;
float humi = 1;
int zahl = 0;
void setup(void)
  dht.begin();
  rtc.begin();
  tft.reset();
  identifier();
  tft.setRotation(3);
  if (!SD.begin())
    return;
  if (! rtc.begin())
      //getValue();
      anzeigen();
      druck2 = false;
      druck = false;
    Serial.print(p.x);
    Serial.print(p.y);
    druck = true;
    druck2 = true;
void anzeigen()
  tft.setTextSize(5);
  tft.print(temp);
  tft.print(" C");
  tft.print(humi);
  tft.println(" %");
  Serial.print(temp);
//temp = 40;
//humi = 40;
//return (text);
String getTime()
  String timeString;
  if (now.day() <= 9)
    timeString = "0";
  timeString += ".";
    timeString += "0";
  timeString += ".";
    timeString += "0";
  timeString += ", ";
    timeString += "0";
  timeString += ":";
    timeString += "0";
  timeString += ":";
    timeString += "0";
  return timeString;
  if (myFile)
    myFile.close();
    zahl++;
    Serial.print(zahl);
    Serial.print("            ");
    myFile.close();
    return;
void identifier()
