Problem with my GPS
I recently bought a GPS module (vpn1513) in order to start working on my project which is building an autonomous guided vehicle. I can’t wrap my head around this GPS module.
I tried to setup and program my GPS as mentioned in the following site
http://playground.arduino.cc/Tutorials/GPS
and the code I’m using :
 #include <string.h>
 #include <ctype.h>
 int ledPin = 13;                  // LED test pin
 int rxPin = 0;                    // RX PIN
 int txPin = 1;                    // TX TX
 int byteGPS=-1;
 char linea[300] = "";
 char comandoGPR[7] = "$GPRMC";
 int cont=0;
 int bien=0;
 int conta=0;
 int indices[13];
   pinMode(ledPin, OUTPUT);       // Initialize LED pin
   pinMode(rxPin, INPUT);
   pinMode(txPin, OUTPUT);
   Serial.begin(4800);
   for (int i=0;i<300;i++){       // Initialize a buffer for received data
     linea[i]=' ';
   digitalWrite(ledPin, HIGH);
   byteGPS=Serial.read();         // Read a byte of the serial port
   if (byteGPS == -1) {           // See if the port is empty yet
     delay(100);
     linea[conta]=byteGPS;        // If there is serial port data, it is put in the buffer
     conta++;
     Serial.print(byteGPS, BYTE);
     if (byteGPS==13){            // If the received byte is = to 13, end of transmission
       digitalWrite(ledPin, LOW);
       cont=0;
       bien=0;
       for (int i=1;i<7;i++){     // Verifies if the received command starts with $GPR
         if (linea[i]==comandoGPR[i-1]){
           bien++;
       if(bien==6){               // If yes, continue and process the data
           if (linea[i]==','){    // check for the position of the  "," separator
             indices[cont]=i;
             cont++;
           if (linea[i]=='*'){    // ... and the "*"
             indices[12]=i;
             cont++;
         Serial.println("");      // ... and write to the serial port
         Serial.println("");
         Serial.println("---------------");
         for (int i=0;i<12;i++){
           switch(i){
             case 0 :Serial.print("Time in UTC (HhMmSs): ");break;
             case 1 :Serial.print("Status (A=OK,V=KO): ");break;
             case 2 :Serial.print("Latitude: ");break;
             case 3 :Serial.print("Direction (N/S): ");break;
             case 4 :Serial.print("Longitude: ");break;
             case 5 :Serial.print("Direction (E/W): ");break;
             case 6 :Serial.print("Velocity in knots: ");break;
             case 7 :Serial.print("Heading in degrees: ");break;
             case 8 :Serial.print("Date UTC (DdMmAa): ");break;
             case 9 :Serial.print("Magnetic degrees: ");break;
             case 10 :Serial.print("(E/W): ");break;
             case 11 :Serial.print("Mode: ");break;
             case 12 :Serial.print("Checksum: ");break;
           for (int j=indices[i];j<(indices[i+1]-1);j++){
             Serial.print(linea[j+1]);
           Serial.println("");
       conta=0;                    // Reset the buffer
         linea[i]=' ';
The GPS light keeps blinking and all I see is nothing on the serial monitor. I tried changing the baud rate and different codes but I get the same problem, either I get a rubbish value or nothing at all.
Can somebody please tell me what I might be doing wrong?
here’s how I have setup my GPS with arduino.
In that picture, you do not appear to be outside. That IS necessary.
Add a Serial.print() statement to print each character that is read from the GPS. Do you receive anything?
Never mind that. You appear to be trying to talk to the GPS and the PC on the same serial port. Forget it. That doesn't work.
I took it outside but still didn't work.. :(
