I am having a problem with my HC-SR04 Range sensor. I’m building a obstacle avoiding robot. Sometimes my robot turns when it has enough space to drive further. Do you know how i can solve this?
This is my code: at void auto_mode() {} is the code for my HC-SR04.
long duration, distance;
int mode;
#define Green 24
#define Red 25
#define trigPin 22
#define echoPin 23
#include <AFMotor.h>
#include <IRremote.h>
int IRpin = 44;
int PotPin = A8;
IRrecv irrecv(IRpin);
decode_results results;
AF_DCMotor motorR(1);
AF_DCMotor motorL(2);
irrecv.enableIRIn();
motorR.setSpeed(100);
motorL.setSpeed(103);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(Green, OUTPUT);
pinMode(Red, OUTPUT);
pinMode(PotPin, INPUT);
checkMode();
void Forward() {
motorR.run(FORWARD);
motorL.run(FORWARD);
void Backward() {
motorR.run(BACKWARD);
motorL.run(BACKWARD);
delay(250);
void Right() {
delay(375);
void Left() {
delay(375);
void Brake() {
motorR.run(RELEASE);
motorL.run(RELEASE);
delay(100);
void auto_mode() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
delay(1);
distance = (duration / 2) / 29.1;
if (distance <= 25) {
Brake();
digitalWrite(Green, LOW);
digitalWrite(Red, HIGH);
Backward();
Brake();
Right();
else if(distance >=26) {
digitalWrite(Red, LOW);
digitalWrite(Green, HIGH);
Forward();
void manual_mode() {
if (irrecv.decode(&results)) {
Serial.print("irCode: ");
Serial.print(results.value, HEX);
Serial.print(", bits: ");
Serial.println(results.bits);
irrecv.resume();
delay(10);
if (results.value == 0xC796DFC || results.value == 0xB10C7C8B) {
Forward();
} else if (results.value == 0xDB510F56) {
Backward();
else if(results.value == 0x4B12992B|| results.value == 0x7E16B93A){
delay(375);
results.value == 0xC796DFC;
delay(10);
else if(results.value == 0x1BE8C80D || results.value == 0x8ECEA106 || results.value == 0xC2A82EEA
delay(375);
delay(10);
else if(results.value == 0xEFF8316D|| results.value == 0xF4704794){
Brake();
else if(results.value == 0x37FF1DB2 || results.value == 0xE5EDF8D7){
Right();
void checkMode(){
mode = analogRead(PotPin);
if(mode <= 512){
manual_mode();
else if(mode >= 513){
auto_mode();
Serial.println(distance);
Try taking several readings, discarding outliers, and using the average.
Sometimes my sensor gives weird numbers like 2389. When i try to solve it in the code it still turns.
use the NewPing library and its ping_median method
DaveEvans:
Can you maybe give me a sample code?
I found a code on google but now im getting this error:
libraries\NewPing\NewPing.cpp.o: In function `__vector_13':
C:\Users\van Grinsven\Documents\Arduino\libraries\NewPing/NewPing.cpp:214: multiple definition of `__vector_13'
libraries\Arduino-IRremote-master\IRremote.cpp.o:C:\Users\van Grinsven\Documents\Arduino\libraries\Arduino-IRremote-master/IRremote.cpp:124: first defined here
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
collect2.exe: error: ld returned 1 exit status
exit status 1
Fout bij compileren.
This is my code now:
#define Green 24
#define Red 25
#define TRIGGER_PIN 22
#define ECHO_PIN 23
#define MAX_DISTANCE 400
#include <NewPing.h>
int IRpin = 44;
int PotPin = A8;
int mode;
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
checkMode();
void Forward() {
void Backward() {
delay(250);
void Right() {
delay(375);
void Left() {
delay(375);
void Brake() {
delay(100);
void auto_mode() {
int dist = sonar.ping_median(5);
dist = sonar.convert_cm(dist);
if (dist < 25 & dist != 0) {
Brake();
Backward();
Brake();
Right();
else {
Forward();
irrecv.resume();
delay(10);
Forward();
Backward();
delay(375);
delay(10);
delay(375);
delay(10);
Brake();
Right();
void checkMode(){
if(mode <= 512){
manual_mode();
auto_mode();
AWOL:
Try here
I did but i couldnt find a answer.
Finaly it is working. I had to comment out Timer 2 in the NewPing lib.
#if defined (AVR_ATmega32U4) // Use Timer4 for ATmega32U4 (Teensy/Leonardo).
ISR(TIMER4_OVF_vect) {
#else
ISR(TIMER2_COMPA_vect) {
//#endif
if(intFunc) intFunc(); // If wrapped function is set, call it.
This part in NewPing.ccp
