Problem with my internet code
I have a code for controlling the lights in my house via web, when i press On , the lights turn on without a problem, but when i press off, the lights turn off and a few seconds later they turn back on. Can anyone help me fix this problem on my code. And if any info on how i can convert my website to a mobile website so i can control them through my iphone would be great, and thanks for help.
Code below:
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
#include <x10.h>
#include <x10constants.h>
const int zeroCrossPin = 2;
const int dataPin = 3;
x10 myHouse = x10(zeroCrossPin, dataPin);
Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
//start Ethernet
server.begin();
// myservo.write(90); //set initial servo position if desired
// myservo.attach(7); //the pin for the servo control
//enable serial data print
// Serial.println("server servo/pin 5 test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
// Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println();
client.println("");
client.println("");
client.println("Arduino GET test page");
client.println("");
client.println("");
client.println("
Family Lights
client.println("<a href="/?on"">ON");
client.println("<a href="/?off"">OFF");
client.println("");
client.println("");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("off") >0)//checks for off
Serial.println("Lights off:");
myHouse.write(A, UNIT_1, 3);
myHouse.write(A, OFF, 3);
myHouse.write(B, UNIT_1, 3);
myHouse.write(B, OFF, 3);
myHouse.write(C, UNIT_1, 3);
myHouse.write(C, OFF, 3);
// myservo.write(140);
// digitalWrite(5, LOW); // set pin 4 low
// Serial.println("Led Off");
if(readString.indexOf("on") >0)//checks for on
Serial.println("Lights on:");
myHouse.write(A, ON, 3);
myHouse.write(B, ON, 3);
myHouse.write(C, ON, 3);
// myservo.write(40);
// digitalWrite(5, HIGH); // set pin 4 high
// Serial.println("Led On");
//clearing string for next read
readString="";
What is in readString when the \n is detected? What does you serial output tell you?
          client.println("<a href=\"/?on\"\">ON</a>");
          client.println("<a href=\"/?off\"\">OFF</a>");
What is the actual HTML source displayed by the browser? You seem to be printing too many quote characters, so it may not be what you expect.
You have debug statements in the code commented out. Why don't you uncomment them so that you can see what HTTP request you're receiving for the 'off' command, and whether the lights are being turned on by the same request or a different request.
