Hello, I was following an Arduino Inscrutable tutorial on IR receiver + leds. The code works perfectly fine but, I'm only receiving 0's from my remote. I would like to be able to read what buttons are being pressed. Could anyone help me with this issue? Thanks! This is the code (I didn't make it):
#include <IRremote.h>
#define first_key 0
#define second_key 58359
#define third_key 539
#define fourth_key 25979
int receiver_pin = 11;
int first_led_pin = 7;
int second_led_pin = 6;
int third_led_pin = 5;
int fourth_led_pin = 4;
int led[] = {0,0,0,0};
IRrecv receiver(receiver_pin);
decode_results output;
receiver.enableIRIn();
pinMode(first_led_pin, OUTPUT);
pinMode(second_led_pin, OUTPUT);
pinMode(third_led_pin, OUTPUT);
pinMode(fourth_led_pin, OUTPUT);
if (receiver.decode(&output)) {
unsigned int value = output.value;
switch(value) {
case first_key:
if(led[1] == 1) {
digitalWrite(first_led_pin, LOW);
led[1] = 0;
digitalWrite(first_led_pin, HIGH);
led[1] = 1;
case second_key:
if(led[2] == 1) {
digitalWrite(second_led_pin, LOW);
led[2] = 0;
digitalWrite(second_led_pin, HIGH);
led[2] = 1;
case third_key:
if(led[3] == 1) {
digitalWrite(third_led_pin, LOW);
led[3] = 0;
digitalWrite(third_led_pin, HIGH);
led[3] = 1;
case fourth_key:
if(led[4] == 1) {
digitalWrite(fourth_led_pin, LOW);
led[4] = 0;
digitalWrite(fourth_led_pin, HIGH);
led[4] = 1;
Serial.println(value);
receiver.resume();
