Problem with my library
Hi friends I want to write my library to push button with debounce.
I have wrote the first version very simple and it works, this is *.h:
#ifndef KeypadLCD_h
#define KeypadLCD_h
#include "Arduino.h"
   #define btnRIGHT  0
   #define btnUP     1
   #define btnDOWN   2
   #define btnLEFT   3
   #define btnSELECT 4
   #define btnNONE   5
class KeypadLCD{
	public:
		KeypadLCD(int pin);
		int ReadButtons();
	private:
		int _pin;
#endif
This is *.cpp:
#include "KeypadLCD.h"
int adc_key_in  = 0;
KeypadLCD::KeypadLCD(int pin){
pinMode(pin, INPUT);
_pin = pin;
int KeypadLCD::ReadButtons(){
   adc_key_in = analogRead(_pin);
   if (adc_key_in > 1000) return btnNONE;
   if (adc_key_in < 50)   return btnRIGHT;
   if (adc_key_in < 195)  return btnUP;
   if (adc_key_in < 380)  return btnDOWN;
   if (adc_key_in < 555)  return btnLEFT;
   if (adc_key_in < 790)  return btnSELECT;
So, I have to write the debounce function into my code.
I would to include this function in the library. I have change my library in this way, *.h:
#ifndef KeypadLCD_h
#define KeypadLCD_h
   #define btnRIGHT  0
   #define btnUP     1
   #define btnDOWN   2
   #define btnLEFT   3
   #define btnSELECT 4
   #define btnNONE   5
class KeypadLCD{
	public:
		KeypadLCD(int pin);
		int ReadButtons();
	private:
		int _pin;
		int conv();
#endif
And *.cpp:
int adc_key_in  = btnNONE;
int stato = 0;
int pre_stato = 0;
unsigned int now = 0;
  _pin = pin;
   stato = analogRead(_pin);
   //Antirimbalzo
  if(pre_stato == 0 && stato != 0){
    pre_stato = conv();
  //Questa condizione mi serve per by-passare l'antirimbalzo per i pulsanti di Up e Down
  if(pre_stato != 0 && (stato == 0 || (((stato > 50 && stato < 195) ||(stato > 195 && stato < 380)) && millis() > (now - 1000)))){
   adc_key_in = conv();
   now = millis();
   pre_stato = 0;
  //Fine antirimbalzo
int KeypadLCD::conv(){
	if (stato > 1000) return btnNONE;
   if (stato < 50)   return btnRIGHT;
   if (stato < 195)  return btnUP;
   if (stato < 380)  return btnDOWN;
   if (stato < 555)  return btnLEFT;
   if (stato < 790)  return btnSELECT;
But it doesn’t work. Why?
Thanks for your help.
But it doesn't work.
Rather poor description of the problem.
Uhm really I have test this program:
#include <KeypadLCD.h>
KeypadLCD key(0);
int lcd_key = 0;
void setup(){
  Serial.print("Buongiorno");
void loop(){
  lcd_key = key.ReadButtons();
  switch(lcd_key){
  case btnRIGHT:
    Serial.println("RIGHT ");
  case btnUP:
    Serial.println("UP ");
  case btnDOWN:
    Serial.println("DOWN ");
  case btnLEFT:
    Serial.println("LEFT ");
  case btnSELECT:
    Serial.println("SELECT ");
  case btnNONE:
    Serial.print("NONE ");
  delay(300);
That write on Serial Monitor what button I have pressed. And it doesn’t write anything
Ah, I use the lcd shield
That is not a standard (comes with the IDE) library. To avoid confusion and guesswork, can you link to the actual library that you are using?
If you insert a
Serial.print(lcd_key);
after
what do you get in serial monitor?
The first two *.h and *.cpp are the library that I use and works well. When I press a button I read fow example "btnLEFT" if I have pressed the button LEFT.
The library:
is that I have wrote above.
