I have a problem with a stepper motor.
This motor is controlled via EasyDriver and encoder.
The encoder also functions as a button (by pressing the button the motor returns to the starting point).
Example:
I turn the encoder to the left, the engine has problems and it turns badly. jerky.
i turn the encoder to the right, the engine runs very well.
I press the encoder to return the engine (which has made many turns to the right) to the starting point, the engine turns to the left very well.
// EasyDriver connections
#define step_pin 9 // Pin 9 connected to Steps pin on EasyDriver
#define dir_pin 8 // Pin 8 connected to Direction pin
#define MS1 10 // Pin 10 connected to MS1 pin
#define MS2 11 // Pin 11 connected to MS2 pin
#define SLEEP 12 // Pin 12 connected to SLEEP pin
volatile boolean TurnDetected; // need volatile for Interrupts
volatile boolean rotationdirection; // CW or CCW rotation
// Rotary Encoder Module connections
const int PinCLK=2; // Generating interrupts using CLK signal
const int PinDT=3; // Reading DT signal
const int PinSW=4; // Reading Push Button switch
int StepperPosition=0; // To store Stepper Motor Position
int StepsToTake=4; // Controls the speed of the Stepper per Rotary click
int direction; // Variable to set Rotation (CW-CCW) of stepper
// Interrupt routine runs if CLK goes from HIGH to LOW
void rotarydetect () {
delay(4); // delay for Debouncing
if (digitalRead(PinCLK))
rotationdirection= digitalRead(PinDT);
rotationdirection= !digitalRead(PinDT);
TurnDetected = true;
void setup () {
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(dir_pin, OUTPUT);
pinMode(step_pin, OUTPUT);
pinMode(SLEEP, OUTPUT);
digitalWrite(SLEEP, HIGH); // Wake up EasyDriver
delay(5); // Wait for EasyDriver wake up
/* Configure type of Steps on EasyDriver:
// MS1 MS2
// LOW LOW = Full Step //
// HIGH LOW = Half Step //
// LOW HIGH = A quarter of Step //
// HIGH HIGH = An eighth of Step //
digitalWrite(MS1, LOW); // Configures to Full Steps
digitalWrite(MS2, LOW); // Configures to Full Steps
pinMode(PinCLK,INPUT); // Set Pin to Input
pinMode(PinDT,INPUT);
pinMode(PinSW,INPUT);
digitalWrite(PinSW, HIGH); // Pull-Up resistor for switch
attachInterrupt (0,rotarydetect,FALLING); // interrupt 0 always connected to pin 2 on Arduino UNO
void loop () {
if (!(digitalRead(PinSW))) { // check if button is pressed
if (StepperPosition == 0) { // check if button was already pressed
if (StepperPosition > 0) { // Stepper was moved CW
while (StepperPosition != 0){ // Do until Motor position is back to ZERO
digitalWrite(dir_pin, HIGH); // (HIGH = anti-clockwise / LOW = clockwise)
for (int x = 1; x < StepsToTake; x++) {
digitalWrite(step_pin, HIGH);
delay(1);
digitalWrite(step_pin, LOW);
delay(1);
StepperPosition=StepperPosition-StepsToTake;
else {
digitalWrite(dir_pin, LOW); // (HIGH = anti-clockwise / LOW = clockwise)
delay(1);
delay(1);
StepperPosition=StepperPosition+StepsToTake;
StepperPosition=0; // Reset position to ZERO after moving motor back
// Runs if rotation was detected
if (TurnDetected) {
TurnDetected = false; // do NOT repeat IF loop until new rotation detected
// Which direction to move Stepper motor
if (rotationdirection) { // Move motor CCW
delay(1);
delay(1);
if (!rotationdirection) { // Move motor CW
delay(1);
delay(1);
