hi am trying to send http requests from nodemcu so i started by uploading the esp8266 library but when i run th following code
#include <ESP8266HTTPClient.h>
#include <ESP8266WiFi.h>
Serial.begin(115200); //Serial connection
WiFi.begin("Iphone de elaa", "27343550"); //WiFi connection
while (WiFi.status() != WL_CONNECTED) { //Wait for the WiFI connection completion
Serial.println("Waiting for connection");
if(WiFi.status()== WL_CONNECTED){ //Check WiFi connection status
HTTPClient http; //Declare object of class HTTPClient
http.begin("http://localhost:8080/getallcadres/getnbpassage/5"); //Specify request destination
http.addHeader("Content-Type", "text/plain"); //Specify content-type header
int httpCode = http.POST("5"); //Send the request
String payload = http.getString(); //Get the response payload
Serial.println(httpCode); //Print HTTP return code
Serial.println(payload); //Print request response payload
http.end(); //Close connection
}else{
Serial.println("Error in WiFi connection");
delay(30000); //Send a request every 30 seconds
i got this error
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), ck, 26 MHz, 40MHz, DOUT (compatible), 512K (no SPIFFS), 2, nonos-sdk 2.2.1 (legacy), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Build options changed, rebuilding all
In file included from C:\Users\ELA_HIDRI\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecure.h:41:0,
from C:\Users\ELA_HIDRI\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiServerSecure.h:20,
from C:\Users\ELA_HIDRI\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:41,
from C:\Users\ELA_HIDRI\Desktop\PFE_ING\nodemcu\nodemcu.ino:2:
C:\Users\ELA_HIDRI\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:38:5: error: 'BearSSL::WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
~WiFiClientSecure() override;
C:\Users\ELA_HIDRI\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:41:9: error: 'int BearSSL::WiFiClientSecure::connect(const String&, uint16_t)' marked override, but does not override
int connect(const String& host, uint16_t port) override;
C:\Users\ELA_HIDRI\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:46:12: error: 'size_t BearSSL::WiFiClientSecure::write_P(const char*, size_t)' marked override, but does not override
size_t write_P(PGM_P buf, size_t size) override;
C:\Users\ELA_HIDRI\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:58:12: error: 'size_t BearSSL::WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
size_t peekBytes(uint8_t *buffer, size_t length) override;
Multiple libraries were found for "WiFiClient.h"
Used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\WiFi
Not used: C:\Users\ELA_HIDRI\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi
exit status 1
Error compiling for board Generic ESP8266 Module.
so what is this error why i am getting it
