Problem with numbers... again
Now I got the opposite problem of what I had yesterday.
I got a number between 1 and 1000.
This number needs to be seperated into 4 different numbers.
1337
needs to become 1, 3, 3, 7.
I’ve tried dividing:
Like so:
Number 1 = 1337 / 1000 = 1,337
Number 2 = 1337 / 100 = 13,37 (here’s the problem)
I’m stuck with 13,37.
I figured, if I write
int x = 0;
if ((1337 / 100) >= 10 && (1337 / 100) < 20)
x = 1;
and have number 2 = (1337-100)-(10 * x);
But doing this 10 times for every digits seems an awful lots of waste of time and coding space to do for something that should be alot simpler.
Short said: I need to round off the number, down. I need to get rid of whatever there is of decimals and just round every decimal down to 0.
Suggestions?
Maybe you should set a different goal. 1337 is not between 1 and 1000.
Only if you use floating-point division
OK, so here it is:
digit0=number%10;
digit1=number/10%10;
digit2=number/10/10%10;
digit3=number/10/10/10%10;
I think this is very understandable once you read up on % operator.
Thanks, but I actually figured it out before your post, ludr.
I was fooling myself until AWOL replied.
I made the wrong calculations by thinking the variable would be floating.
Once AWOL said it wasn’t, the rest was pretty straight forward.
This is one of the paragraphs: (it works btw)
if ( counter >= 1000 && counter < 10000)
input1 = analogvalue / 1000;
input2 = (analogvalue / 100) - (input1 * 10 );
input3 = (analogvalue / 10) - (input1 * 100) - (input2 * 10);
input4 = (analogvalue - (input1 * 1000) - (input2 * 100) - (input3 * 10));
Glad you figured it out. Still if you use % it will look easier.
