Hello,
I have a small project that involves on-on type switch. I have connected the switch to Arduino Uno board, wrote some simple code and run it. Switch is connected to pins 2 and 3. Buzzer is connected to pin 8, and I'm using build in LED (just for now).
Generally speaking... it works. When I pull the switch down I get sound, when I pull it up, LED blinks (or the other way around... does not matter). But... every now and then:
-when LED is set to be blinking, buzzer makes sound
- when buzzer is set to be making noise, LED blinks
and this happens in a random way.
I figure out, that there must be something wrong with both switch state detection and my code (to compensate the erratic behavior). The question is: what shall I correct (in both code and schematix) to eradicate described behavior ?
The sketch (simplified, to show the problem):
int led = 13;
int buttonPin1 = 2;
int buttonPin2 = 3;
int buttonState1 = 0;
int buttonState2 = 0;
void setup(){
pinMode(led, OUTPUT);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
void loop(){
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
if(buttonState1 == HIGH){
make_sound;
if(buttonState2 == HIGH){
make_noise;
int make_sound(){
for(int i = 0; i < 4; i++){
digitalWrite(led, HIGH);
delay(50);
digitalWrite(led, LOW);
delay(200);
int make_noise(){
tone(8,1000,10);
delay(250);
And the schematic (shared via my dropbox):
https://www.dropbox.com/sh/2kobwl0s6y71dyo/5rYSO98xed#/
Thanks in advance for any response.
BR ![]()
blackest
