Sorry, they were in the link since ?I did not think I could post more, but I see I can post in replies.
and here is the code:
#include <Servo.h>
// Create servo objects
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
// Create names to the analog input pins
int pin0 = A0;
int pin1 = A1;
int pin2 = A2;
int pin3 = A3;
// Setup of angle variables we have to use further down in the program
int angle1;
int angle2;
int angle3;
int angle4;
// Setup of value variables we have to use further down in the program
int value1;
int value2;
int value3;
int value4;
// Setup of limit values
long int forservo1 = 20000;
long int forservo2 = 20000;
long int forservo3 = 20000;
long int forservo4 = 20000;
pinMode(3, INPUT); /* Use button on thumbstick to set pin 3 as input /
pinMode(4, OUTPUT); / Set pin 4 as output to the magnet */
// Attaches the servo on pins to the servo objects
servo1.attach(5);
servo2.attach(6);
servo3.attach(9);
servo4.attach(10);
// read analog values from joysticks
value1 = analogRead(pin0);
value2 = analogRead(pin1);
value3 = analogRead(pin2);
value4 = analogRead(pin3);
// 10 bit value is too big, so we change the scale from 0 - 1023 proportionately to 1 - 29
value1 = map(value1, 0, 1023, 1, 29);
value2 = map(value2, 0, 1023, 1, 29);
value3 = map(value3, 0, 1023, 1, 29);
value4 = map(value4, 0, 1023, 1, 29);
// it needs correction of positions, because joysticks are not very precise to stay exactly in the center
if(value1 <= 17 && value1 >= 13) // if value1 if between 13-17, then it's equal to 15 */
value1 = 15;
if(value2 <= 17 && value2 >= 13)
value2 = 15;
if(value3 <= 17 && value3 >= 13)
value3 = 15;
if(value4 <= 17 && value4 >= 13)
value4 = 15;
// Change initial value 'forservo' which is used to turn servo slower. This value has got very big scale.
// We add or substract (depends on turning direction) difference between analog value and center from 'forservo'
forservo1 = forservo1 - (value1 - 15);
forservo2 = forservo2 - (value2 - 15);
forservo3 = forservo3 + (value3 - 15);
forservo4 = forservo4 + (value4 - 15);
// this part do not let variables 'forservo' go out of the limits
if(forservo1 < 1) // if forservo1 is less than 1, then it's equal to 1
forservo1 = 1;
if(forservo1 > 20000) // if forservo1 is greater than 20000, then it's equal to 20000
forservo1 = 20000;
if(forservo2 < 1)
forservo2 = 1;
if(forservo2 > 20000)
forservo2 = 20000;
if(forservo3 < 1)
forservo3 = 1;
if(forservo3 > 20000)
forservo3 = 20000;
if(forservo4 < 1)
forservo4 = 1;
if(forservo4 > 20000)
forservo4 = 20000;
// change used value to angle of servo. Angles are adjusted during testing
angle1 = map(forservo1, 1, 20000, 10, 180);
angle2 = map(forservo2, 1, 20000, 10, 180);
angle3 = map(forservo3, 1, 20000, 10, 180);
angle4 = map(forservo4, 1, 20000, 10, 180);
// send angles to servos
servo1.write(angle1);
servo2.write(angle2);
servo3.write(angle3);
servo4.write(angle4);
// activates the magnet
while (digitalRead(3) == HIGH) { /* Read pin 3 from the thumbstick /
digitalWrite(4, HIGH); / Write to pin 4 (magnet) */
