Hello everyone!
My problem is as follow: I have written small function which is blinking a led with fixed interval, just like turn indicator in a car. When I use this function only once, let's say for left side blinker it works good, but when I use it twice, then the LED is lit for a fracture of second.
What I have noticed is that when I remove else lightOn = false;this line, then both LEDs are on together.
// Auto blinker switch example.
// The auto blinker question comes up regulary in the Arduino forum so
// I figured an example of that would be just the ticket. This uses two
// binker objects for the blinking LEDs and three mechButton objects for
// the three buttons. A left, right and Hazard button. The first press
// of a button, say right, turns on that blinker. The second turns it
// back off. If another button is pressed, say left then the code just
// switches from right to left. So each button is one click on, second
// click off.
// The buttons should be wired one side to the pin number choosen and
// the other to ground. the mechButton object will do the debounceing
// for you as well as call your callback routines when clicked. The
// blinker objects take care of the blinking. All these behind the
// scenes functions happen when you call idle() in your loop function.
// You can add more stuff to your loop() function if you want. But DO
// NOT USE delay(). No fear, this stuff comes with sleep() wich acts
// on the main loop() just like delay(), but lets the background stuff
// keep running.
// Have fun!
// jim lee
#include <blinker.h>
#include <mechButton.h>
#define BLINK_PERIOD 1000 // Ms
#define BLINK_LIT 500 // ms
#define BLINK_L_PIN 5 // Pin NUM
#define BLINK_R_PIN 6 // Pin NUM
#define BTN_L_PIN 2 // Pin NUM
#define BTN_R_PIN 3 // Pin NUM
#define BTN_H_PIN 4 // Pin NUM
enum blinkComs { blinkOff, blinkLeft, blinkRight, blinkHazard }; // Set up our list of states.
blinkComs currentState; // A variable to save our current state.
blinker leftBlinker(BLINK_L_PIN, BLINK_LIT, BLINK_PERIOD); // The left blinker object. A "fire and forget" blinker object.
blinker rightBlinker(BLINK_R_PIN, BLINK_LIT, BLINK_PERIOD); // The right blinker object. Same as left, different pin.
mechButton lButton(BTN_L_PIN); // The left blinker button. Another "fire and forget" object.
mechButton rButton(BTN_R_PIN); // The right blinker button. Same as left, different pin.
mechButton hButton(BTN_H_PIN); // And your hazard button. Wouldn't be complete without them.
// Standard setup.
currentState = blinkOff; // We start with the blinkers off. So note that.
lButton.setCallback(clickLBtn); // Hook the button objects to their respective callbacks.
rButton.setCallback(clickRBtn); // Hooking..
hButton.setCallback(clickHBtn); // Hooking..
// When the LEFT button is clicked, this is called..
void clickLBtn(void) {
if (!lButton.trueFalse()) { // If the button has been grounded..
if (currentState == blinkLeft) { // If we are already doing this mode..
setBlinkers(blinkOff); // We just shut off everything.
} else { // Else, doing something else..
setBlinkers(blinkLeft); // We switch to our mode.
// When the RIGHT button is clicked, this is called..
void clickRBtn(void) {
if (!rButton.trueFalse()) { // If the button has been grounded..
if (currentState == blinkRight) { // If we are already doing this mode..
setBlinkers(blinkRight); // We switch to our mode.
// When the HAZARD button is clicked, this is called..
void clickHBtn(void) {
if (!hButton.trueFalse()) { // If the button has been grounded..]
if (currentState == blinkHazard) { // If we are already doing this mode..
setBlinkers(blinkHazard); // We switch to our mode.
// Set the blinkers to a new mode. Then note what mode they are in.
void setBlinkers(blinkComs theBlinkCom) {
switch (theBlinkCom) { // If the new mode is..
case blinkOff : // blinkOff.
leftBlinker.setOnOff(false); // Left blinker off.
rightBlinker.setOnOff(false); // Right blinker off.
case blinkLeft : // blinkLeft
leftBlinker.setOnOff(true); // Left blinker on.
case blinkRight : // blinkRight
rightBlinker.setOnOff(true); // Right blinker on.
case blinkHazard : // blinkRight
leftBlinker.setOnOff(false); // Left blinker off. (Both off to synk them up)
currentState = theBlinkCom; // And note the new state of the universe.
// Everything is run behind the scenes so all loop()
// needs to do is call idle() to let it all run.
idle();
You'll need LC_baseTools installed (IDE library manager) to compile it.
