problem with percentage calculator
hello… any here can help me to check my code? i have problem with my code… i m just start program arduino several months ago… so im beginner…
i want to reduce output by% when output reach 130
i write the code but nothing happen…
not reduce the output
any hear can check it for me what i m wrong?
SORRY FOR MY ENGLISH
// SPI //
// Arduino nano Test 168/328p //
//wire library for SPI communication
#include <SPI.h>
//////////////////Begin library definitions section/////////////////
const int slaveSelectPin = 10;
int BoostPin = 0; // variable to store the sensor pin anlog1
int ScrB = 9; //Powertune value for voltage reduction
int sensorValue = 400; // variable to store the value coming from the sensor
// set the slaveSelectPin as an output:
pinMode (slaveSelectPin, OUTPUT);
// initialize SPI:
SPI.begin();
float percent;
int DACval; // Store D/A value
sensorValue = analogRead(BoostPin); // read sensor value and store
DACval = (sensorValue / 4); // devide with 4 to make 0-1024 to 0-255 and add 2 for value alignment to 1020mbar
if(DACval > 130 ) // if more then 1300 mbar reduce dac value for scrambling
percent = (ScrB / 10) * (DACval);// percentage calculation
DACval = DACval - percent; // value reducer
digitalPotWrite(19, DACval);
void digitalPotWrite(int address, int value)
// take the SS pin low to select the chip:
digitalWrite(slaveSelectPin, LOW);
// send in the address and value via SPI:
SPI.transfer(address);
SPI.transfer(value);
// take the SS pin high to de-select the chip:
digitalWrite(slaveSelectPin, HIGH);
ScrB is an integer value set to 9, so (ScrB / 10) is always equal to zero. Consequently, percent is always assigned the value zero.
try:
percent = DACval * ScrB / 10;
so how can i change this code to reduce 20 %... i m low knowledge in math..
arduinodlb: try:
not work still no reduce an output
As in this?
DACval = DACval * 8 / 10;
Get out a pocket calculator and start playing around with numbers.
9 / 10 = 0
9.0 / 10 = 0.9
uncle_inside:
Maybe DACval never exceeded 130.
AWOL:
9 / 10 = 0
9.0 / 10 = 0.9
thank friend…
i change ScrB=50… but output not go down its turn to high output in 3.5 volt out 4++volt… so how do i rotate this to make it go down?
I’m sorry, I don’t understand the question.
Can you post your code again (with code tags) with your observations, please?
Edit: Are you saying 50/10 gives the wrong results?
AWOL: I'm sorry, I don't understand the question. Can you post your code again (with code tags) with your observations, please?
you gift me an idea.... problem solve...
one more question... how to post code inside something like you all post?
i post long code how to put inside
//                          SPI                             //
#include <SPI.h>
  // initialize SPI:
  SPI.begin();
  float percent;
    percent = (ScrB / 9.75) * (DACval /4);// percentage calculation
You appear to be dividing the original reading by 16 - is that intentional?
thank to all who try to help me to solve my problem... now my code working nicely
