Problem with PID library to control motor speed
I’ve use the PID_v1 library for motor speed control.
Lets say my setpoint is 50 and input is read from speed encoder in rpm
The question is
Do I need a feed foward PWM + Output from PID to drive a motor
Like analogWrite(50+Output) or I only need to Write only Output.
Because when I only use Output to drive a motor it will oscillate up and down
like it’s unstable. Is it because my Kp Ki or Kd is the value that unstable?
I see that if we concern only kp. It will be Error= setpoint-input and Output= Kp* Error
If the setpoint and input are both equal which mean no error then the output is zero.
Then there’s the problem.
Thanks
Use Output only.
If the speed oscillates, Kp is probably too high. Google "PID tuning" for tutorials on selecting the K values.
