Problem with PIR sensor + GSM shield
Hi, I have a good working PIR sensor. I tested it with this tutorial (http://makezine.com/projects/PIR-Sensor-Arduino-Alarm/)
Problem: When I use GSM shield and POST request PIR sensor works bad, not the way it should. Signal HIGH gets after request. When I comment POST function, it works fine.
Code:
void connectToServer()
  //Serial.println(F("Jungiamasi prie GSM"));
  if(gprs.ready())
      // bando prisijungti
      if (client.connect("securitysystem2-001-site1.myasp.net", 80))
        //Siunciama POST uzklausa
        //delay(500);
        char buffer[12];
        itoa(guard_status, buffer, 10);
        Serial.println(F("POST"));
        client.println(F("POST /TCPEndPoint.ashx HTTP/1.1"));
        client.println(F("Host: securitysystem2-001-site1.myasp.net"));
        client.println(F("Content-Type: application/x-www-form-urlencoded"));
        client.print(F("Content-Length: "));
        client.println(strlen(buffer));
        client.println(F("Connection: close"));
        client.println();
        client.println(buffer);
        Serial.print(F("Kintamasis="));  Serial.println(buffer);
        Serial.print(F("SRAM="));  Serial.println(freeRam());
        //lcd.clear();
        //lcd.print("Serv:Klaida");
        Serial.println(F("Neprisijungta prie serverio"));
    //lcd.clear();
    //lcd.print("GSM:Klaida");
    connectGSM();
This is a big problem for me. 2 week trying to fix it.
Sory for bad english, I hope you understand.
