Problem with pollserial of TVout lib
Hi all
Downloaded the TVout lib from here http://code.google.com/p/arduino-tvout/, did the whole installation thing and the IDE picks it up.
The problem I'm having is with the supplied example for the serial terminal:
#include <TVout.h>
#include <pollserial.h>
#include <fontALL.h>
TVout TV;
pollserial pserial;
void setup()  {
  TV.begin(_PAL,128,96);
  TV.select_font(font6x8);
  TV.println("Serial Terminal");
  TV.println("-- Version 1.0 --");
  TV.set_hbi_hook(pserial.begin(57600));
  if (pserial.available()) {
    TV.print((char)pserial.read());
When trying to compile, this is what I get:
In file included from TVoutTerminal.ino:4:
..\arduino-1.0.5\libraries\pollserial/pollserial.h:46: error: conflicting return type specified for 'virtual void pollserial::write(uint8_t)'
..\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
..\arduino-1.0.5\libraries\TVout/video_gen.h:63: warning: 'void wait_until(uint8_t)' declared 'static' but never defined
..\arduino-1.0.5\libraries\TVout/TVout.h:176: warning: 'void sp(unsigned char, unsigned char, char)' declared 'static' but never defined
Can anyone shed some light on these errors and warnings?
Thank you.
Never mind, problem solved.
http://code.google.com/p/arduino-tvout/issues/detail?id=50
Hi there, i know this is a very old topic, but the thing is i dont have acces to google code. i live in cuba, is blocked. 403-forbidden says google.
any other possible links to this library??
Thanks! I'll check it out.
Also:- GitHub - Avamander/arduino-tvout: Arduino-TVout
