Problem with potentiometer, switch in setting lighting sequence with Arduino Uno
I am currently work on a project that is very similar to the project found here. It involves the use of an Aruino Uno, LED stripping, a potentiometer and a switch.
I have used the following code:
#include "LPD8806.h"
#include "SPI.h"
int led = 13;
int dataPin = 2;
int clockPin = 3;
// Set the first variable to the NUMBER of pixels. 32 = 32 pixels in a row
// The LED strips are 32 LEDs per meter but you can extend/cut the strip
LPD8806 strip = LPD8806(96, dataPin, clockPin);
  // Start up the LED strip
  strip.begin();
  // Update the strip, to start they are all 'off'
  strip.show();
// function prototypes, do not remove these!
void colorChase(uint32_t c, uint8_t wait);
void colorWipe(uint32_t c, uint8_t wait);
void dither(uint32_t c, uint8_t wait);
void scanner(uint8_t r, uint8_t g, uint8_t b, uint8_t wait);
void wave(uint32_t c, int cycles, uint8_t wait);
void rainbowCycle(uint8_t wait);
uint32_t Wheel(uint16_t WheelPos);
  // Send a simple pixel chase in...
  colorChase(strip.Color(127,127,127), 20); // white
  colorChase(strip.Color(127,0,0), 20);     // red
  colorChase(strip.Color(127,127,0), 20);   // yellow
  colorChase(strip.Color(0,127,0), 20);     // green
  colorChase(strip.Color(0,127,127), 20);   // cyan
  colorChase(strip.Color(0,0,127), 20);     // blue
  colorChase(strip.Color(127,0,127), 20);   // magenta
  // Fill the entire strip with...
  colorWipe(strip.Color(127,0,0), 20);      // red
  colorWipe(strip.Color(0, 127,0), 20);     // green
  colorWipe(strip.Color(0,0,127), 20);      // blue
  colorWipe(strip.Color(0,0,0), 20);        // black
  // Color sparkles
  dither(strip.Color(0,127,127), 50);       // cyan, slow
  dither(strip.Color(0,0,0), 15);           // black, fast
  dither(strip.Color(127,0,127), 50);       // magenta, slow
  dither(strip.Color(127,127,0), 50);       // yellow, slow
  // Back-and-forth lights
  scanner(127,0,0, 30);        // red, slow
  scanner(0,0,127, 15);        // blue, fast
  // Wavy ripple effects
  wave(strip.Color(127,0,0), 4, 20);        // candy cane
  wave(strip.Color(0,0,100), 2, 40);        // icy
  // make a pretty rainbow cycle!
  rainbowCycle(0);  // make it go through the cycle fairly fast
  // Clear strip data before start of next effect
  for (int i=0; i < strip.numPixels(); i++) {
    strip.setPixelColor(i, 0);
// Cycle through the color wheel, equally spaced around the belt
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for (j=0; j < 384 * 5; j++) {     // 5 cycles of all 384 colors in the wheel
    for (i=0; i < strip.numPixels(); i++) {
      // tricky math! we use each pixel as a fraction of the full 384-color
      // wheel (thats the i / strip.numPixels() part)
      // Then add in j which makes the colors go around per pixel
      // the % 384 is to make the wheel cycle around
      strip.setPixelColor(i, Wheel(((i * 384 / strip.numPixels()) + j) % 384));
    strip.show();   // write all the pixels out
    delay(wait);
// fill the dots one after the other with said color
// good for testing purposes
void colorWipe(uint32_t c, uint8_t wait) {
  int i;
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
// Chase a dot down the strip
void colorChase(uint32_t c, uint8_t wait) {
  int i;
    strip.setPixelColor(i, 0);  // turn all pixels off
      strip.setPixelColor(i, c); // set one pixel
      strip.show();              // refresh strip display
      delay(wait);               // hold image for a moment
      strip.setPixelColor(i, 0); // erase pixel (but don't refresh yet)
  strip.show(); // for last erased pixel
// An "ordered dither" fills every pixel in a sequence that looks
// sparkly and almost random, but actually follows a specific order.
void dither(uint32_t c, uint8_t wait) {
  // Determine highest bit needed to represent pixel index
  int hiBit = 0;
  int n = strip.numPixels() - 1;
  for(int bit=1; bit < 0x8000; bit <<= 1) {
    if(n & bit) hiBit = bit;
  int bit, reverse;
  for(int i=0; i<(hiBit << 1); i++) {
    // Reverse the bits in i to create ordered dither:
    reverse = 0;
    for(bit=1; bit <= hiBit; bit <<= 1) {
      reverse <<= 1;
      if(i & bit) reverse |= 1;
    strip.setPixelColor(reverse, c);
    strip.show();
    delay(wait);
  delay(250); // Hold image for 1/4 sec
// "Larson scanner" = Cylon/KITT bouncing light effect
void scanner(uint8_t r, uint8_t g, uint8_t b, uint8_t wait) {
  int i, j, pos, dir;
  pos = 0;
  dir = 1;
  for(i=0; i<((strip.numPixels()-1) * 8); i++) {
    // Draw 5 pixels centered on pos.  setPixelColor() will clip
    // any pixels off the ends of the strip, no worries there.
    // we'll make the colors dimmer at the edges for a nice pulse
    // look
    strip.setPixelColor(pos - 2, strip.Color(r/4, g/4, b/4));
    strip.setPixelColor(pos - 1, strip.Color(r/2, g/2, b/2));
    strip.setPixelColor(pos, strip.Color(r, g, b));
    strip.setPixelColor(pos + 1, strip.Color(r/2, g/2, b/2));
    strip.setPixelColor(pos + 2, strip.Color(r/4, g/4, b/4));
    strip.show();
    delay(wait);
    // If we wanted to be sneaky we could erase just the tail end
    // pixel, but it's much easier just to erase the whole thing
    // and draw a new one next time.
    for(j=-2; j<= 2; j++)
        strip.setPixelColor(pos+j, strip.Color(0,0,0));
    // Bounce off ends of strip
    pos += dir;
    if(pos < 0) {
      pos = 1;
      dir = -dir;
    } else if(pos >= strip.numPixels()) {
      pos = strip.numPixels() - 2;
      dir = -dir;
// Sine wave effect
#define PI 3.14159265
void wave(uint32_t c, int cycles, uint8_t wait) {
  float y;
  byte  r, g, b, r2, g2, b2;
  // Need to decompose color into its r, g, b elements
  g = (c >> 16) & 0x7f;
  r = (c >>  8) & 0x7f;
  b =  c        & 0x7f;
  for(int x=0; x<(strip.numPixels()*5); x++)
    for(int i=0; i<strip.numPixels(); i++) {
      y = sin(PI * (float)cycles * (float)(x + i) / (float)strip.numPixels());
      if(y >= 0.0) {
        // Peaks of sine wave are white
        y  = 1.0 - y; // Translate Y to 0.0 (top) to 1.0 (center)
        r2 = 127 - (byte)((float)(127 - r) * y);
        g2 = 127 - (byte)((float)(127 - g) * y);
        b2 = 127 - (byte)((float)(127 - b) * y);
        // Troughs of sine wave are black
        y += 1.0; // Translate Y to 0.0 (bottom) to 1.0 (center)
        r2 = (byte)((float)r * y);
        g2 = (byte)((float)g * y);
        b2 = (byte)((float)b * y);
      strip.setPixelColor(i, r2, g2, b2);
    strip.show();
    delay(wait);
/* Helper functions */
//Input a value 0 to 384 to get a color value.
//The colours are a transition r - g - b - back to r
  byte r, g, b;
  switch(WheelPos / 128)
    case 0:
      r = 127 - WheelPos % 128; // red down
      g = WheelPos % 128;       // green up
      b = 0;                    // blue off
    case 1:
      g = 127 - WheelPos % 128; // green down
      b = WheelPos % 128;       // blue up
      r = 0;                    // red off
    case 2:
      b = 127 - WheelPos % 128; // blue down
      r = WheelPos % 128;       // red up
      g = 0;                    // green off
  return(strip.Color(r,g,b));
The ultimate goal is to be able to use the potentiometer to select a specific sequence (value of 1-8), then flick the switch to reset the Arduino and use the new setting to see the new sequence.
It is currently cycling through the various sequences, but it doesn’t seem to let me choose with the use of the potentiometer and switch.
I’m wondering if there is some code missing, or there is something that I am overlooking because of my lack of experience. This is my first Arduino project and am excited to do more projects in the future.
Thanks for your help!
Maybe I'm missing something because I didn't carefully study your code, but I don't see where you are reading a pot or a switch... Is that in your code somewhere?
And using a pot as a selector switch could work but IMO it's kind of a screwy thing to do because you may not know for sure what mode is selected. Maybe it would be OK if you had 8 LEDs indicating what function is selected, but in that case I'd probably just use a push-button to step to the next function.
Not being completely familiar with coding I wondered if this code was missing (I too didn’t see a read on a pot as well).
I like the idea of a switch to cycle through the sequences. Any ideas on what that would look like code wise?
jetz66:
Try writing a short sketch with a variable that keeps track of the position in the cycle (number 0- 7), increases the number with each button press and displays the value on the Serial Monitor. Probably about 10 lines of code.
...R
I'll work on that! Thanks!
