I have a code that takes a sensor value from MPU6050 as absolutegyroX and applies pow(2,(absolutegyroX/31)); function to it.
However somehow when I test the arduino POW functions return values with a spreadsheet softwares POWER function they do not match. What am I missing here?
for example 59 yields 2 in Arduino code and 4 in Excel Spreadsheet.
SensorValue / Arduino Code / Excel Spreadsheet
70 3 5
78 3 6
78 3 6
89 3 7
70 3 5
59 2 4
33 2 2
59 2 4
96 7 9
132 15 19
181 31 57
227 127 160
122 7 15
105 7 10
and such.
Pasting entire code below:
#include "FastLED.h" // FastLED library.
////////////////////////////////////////////POTENTIOMETER
int pot1PinA0 = A7;
int pot1RAWValue = 0;
const int numReadings1 = 10;
int readings1[numReadings1]; // the readings from the analog input
int index1 = 0; // the index of the current reading
int total1 = 0; // the running total
int average1 = 0; // the average
int Pot1MappedOutputValue = 32;
////////////////////////////////////////////POTENTIOMETER////////////////////////////////////////////
////////////////////////////////////////////////SMOOTHING
#include <movingAvg.h>
movingAvg avgGYRO(5);*/
int rawValGyroX = 0; // sensor raw value
int rawValGyroY = 0; // sensor raw value
int rawValGyroZ = 0; // sensor raw value
float smoothedVal = 0.0; // sensor smoothed value
float smoothStrength = 5; // amount of smoothing (default 10)
////////////////////////////////////////////////SMOOTHING/////////////////////////////////////////////////
////////////////////////////////////////////////MPU6050
#include <MPU6050_tockn.h>
#include <Wire.h>
MPU6050 mpu6050(Wire);
long timer = 0;
////////////////////////////////////////////////MPU6050/////////////////////////////////////////////////
////////////////////////////////////////////////FASTLED
uint8_t thishue = 0; // Starting hue value.
uint8_t deltahue = 10;
#define LED_DT 3 // Data pin to connect to the strip.
#define COLOR_ORDER GRB // It's GRB for WS2812B and BGR for APA102
#define LED_TYPE WS2812B // What kind of strip are you using (WS2801, WS2812B or APA102)?
#define NUM_LEDS 300 // Number of LED's.
#define MAX_BRIGHTNESS 128 // Thats full on, watch the power!
#define MIN_BRIGHTNESS 1 // set to a minimum of 25%
struct CRGB leds[NUM_LEDS]; // Initialize our LED array.
////////////////////////////////////////////////FASTLED/////////////////////////////////////////////////
////////////////////////////////////////////////SETUP/////////////////////////////////////////////////
Wire.begin();
LEDS.addLeds<LED_TYPE, LED_DT, COLOR_ORDER>(leds, NUM_LEDS); // Use this for WS2812B
FastLED.setBrightness(MIN_BRIGHTNESS);
mpu6050.begin();
mpu6050.calcGyroOffsets(true);
// TGAN_Potentiometer_1
for (int thisReading1 = 0; thisReading1 < numReadings1; thisReading1++)
readings1[thisReading1] = 0;
Serial.println("");
Serial.print("Millis");
Serial.print(" \t");
Serial.print("absolutegyroX ");
Serial.print(" BrightnessValue ");
}////////////////////////////////////////////////SETUP/////////////////////////////////////////////////
////////////////////////////////////////////////LOOP/////////////////////////////////////////////////
unsigned long curMillis = millis(); // Get current time. to have a sense of sampling rate. 5 digits. First 2 digits are seconds...
mpu6050.update();
pot1RAWValue = analogRead(pot1PinA0);
total1 = total1 - readings1[index1];
readings1[index1] = pot1RAWValue;
total1 = total1 + readings1[index1];
index1 = index1 + 1;
if (index1 >= numReadings1)
index1 = 0;
average1 = total1 / numReadings1;
Pot1MappedOutputValue = map(average1, 5, 780, 24, 40);
int oldPot1MappedOutputValue;
if (Pot1MappedOutputValue != oldPot1MappedOutputValue)
Serial.print("pot1RAWValue : "); Serial.print(pot1RAWValue ); Serial.print(" / Pot1MappedOutputValue: "); Serial.println(Pot1MappedOutputValue);
oldPot1MappedOutputValue = Pot1MappedOutputValue;
//if (millis() - timer > 10) {
Serial.print("&temp &");Serial.print(mpu6050.getTemp());
Serial.print("&accX & ");Serial.print(mpu6050.getAccX());
Serial.print("&taccY& ");Serial.print(mpu6050.getAccY());
Serial.print("&taccZ & ");Serial.print(mpu6050.getAccZ());
Serial.print("&gyroX & ");Serial.print(mpu6050.getGyroX());
Serial.print("&tgyroY & ");Serial.print(mpu6050.getGyroY());
Serial.print("&tgyroZ& ");Serial.print(mpu6050.getGyroZ());
Serial.print("&accAngleX & ");Serial.print(mpu6050.getAccAngleX());
Serial.print("&taccAngleY & ");Serial.print(mpu6050.getAccAngleY());
Serial.print("&gyroAngleX & ");Serial.print(mpu6050.getGyroAngleX());
Serial.print("&tgyroAngleY & ");Serial.print(mpu6050.getGyroAngleY());
Serial.print("&tgyroAngleZ& ");Serial.println(mpu6050.getGyroAngleZ());
Serial.print("&angleX & ");Serial.print(mpu6050.getAngleX());
Serial.print("&tangleY & ");Serial.print(mpu6050.getAngleY());
Serial.print("&tangleZ &");Serial.print(mpu6050.getAngleZ());
// timer = millis(); }
rawValGyroX = mpu6050.getGyroX();
int absolutegyroX = abs(rawValGyroX);
int BrightnessValue = pow(2,(absolutegyroX/31)); //Calculates the value 2 raised to (absolutegyroX/5). Pow() //pow(2,absolutegyroX/5);
Serial.print(curMillis); Serial.print(" \t");Serial.print(" \t"); Serial.print(" \t"); // Get current time. to have a sense of sampling rate. 5 digits. First 2 digits are seconds...
Serial.print(absolutegyroX); Serial.print(" \t");Serial.print(" \t"); Serial.print(" \t");
Serial.print(BrightnessValue);Serial.print(" \t");Serial.print(" \t"); Serial.println(" \t");
EVERY_N_MILLISECONDS(5) { // FastLED based non-blocking routine to update/display the sequence.
rainbow_march();
show_at_max_brightness_for_power();
FastLED.setBrightness(BrightnessValue);
void rainbow_march() { // The fill_rainbow call doesn't support brightness levels
fill_rainbow(leds, NUM_LEDS, thishue, deltahue);
// addGlitter(300);// Use FastLED's fill_rainbow routine.
} // rainbow_march()
void addGlitter( fract8 chanceOfGlitter)
if ( random8() < chanceOfGlitter) {
leds[ random16(NUM_LEDS) ] += CRGB::White;
