Problem with Power Supply Module turning off
I'm trying to learn how to use stepper motor while following Paul Mcwhorter's Arduino tutorials.
Problem is that when I plug arduino to my PC, power supply module led turns off and nothing is happening, whean i plug arduino off led on module lights up.
I'm using ELEGOO UNO 3R, power supply is also form ELEGOO.
Probably code is not a problem but maby someting is wrong.
#include <Stepper.h>
int stepsPerRevolution = 2048;
int motSpeed = 10;
Stepper myStepper(stepsPerRevolution, 8, 10, 9, 11);
int dT = 500;
  myStepper.setSpeed(motSpeed);
  myStepper.step(stepsPerRevolution);
  delay(dT);
  myStepper.step(-stepsPerRevolution);
  delay(dT);
It looks like a power problem. Please provide links to the motor and PSU data sheets.
http://han.unl.edu/pdf/mb-v2%20datasheet.pdf
After trying to troubleshoot I figured out that power supply led turns off when it is connected with motor driver module not to arduino.
How do you power the PSU?
Please supply a circuit diagram.
An ULN2xxx is not usable with a 5V motor and 5V supply. Use a driver with less voltage drop (MOSFET...).
@xkmx, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
28BYJ-48 steppers are commonly supplied with an ULN2003, and that combo works fine on 5volt.
How do you power that breadboard supply (voltage/current).
Note that a breadboard supply has the same thermal limitations as the supply of an Uno.
Post a picture of the setup.
Leo..
