Problem with pressuer sensor mpx4115 in proteus app
I'm facing an issue using the MPX4115 pressure sensor in Proteus, and I'm unsure if the problem lies with the simulation software or my code. I've included the conversion equations to kPa from the sensor's datasheet, but I'm still getting incorrect readings. For instance, when I input a pressure of 101 kPa, the display shows 81.44 kPa. Should I consider changing the version of the simulation software, or is there a necessary adjustment in my code? #include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int sensorPin = A0;
int sensorValue = 0;
lcd.begin(16, 2);
lcd.print("Pressure Sensor");
sensorValue = analogRead(sensorPin);
float voltage = sensorValue * (5.0 / 1023.0);
float pressure = (voltage / 5.0 - 0.095) / 0.009;
Serial.print("Sensor Value: ");
Serial.println(sensorValue);
Serial.print("Pressure (kPa): ");
Serial.println(pressure);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Pressure:");
lcd.setCursor(0, 1);
lcd.print(pressure);
Try removing line two and three in loop, and replace it with this line.
float pressure = ((sensorValue / 1024.0) + 0.095) / 0.009;
You only get one meaningful decimal place in kPa with a 10-bit A/D, so use
Serial.println (pressure, 1);
lcd.print (pressure, 1);
Leo..
