Problem with Pro Micro ICSC.h not compile
Hi there,
I have a problem with an Arduino Micro Pro, ICSC.h not compile, the error I get is as follows:
no matching function for call to 'ICSC::begind(int,long int, Serial*,int)'
C:\Program Files (x86)\Arduino\libraries\ICSC\ICSC.cpp: In member function 'void _ICSC::begin(unsigned char, long unsigned int)':
C:\Program Files (x86)\Arduino\libraries\ICSC\ICSC.cpp:61: error: no matching function for call to 'ICSC::begin(unsigned char&, long unsigned int&, Serial, int)'
C:\Program Files (x86)\Arduino\libraries\ICSC\ICSC.cpp:59: note: candidates are: void _ICSC::begin(unsigned char, long unsigned int)
C:\Program Files (x86)\Arduino\libraries\ICSC/ICSC.h:186: note: void _ICSC::begin(unsigned char, long unsigned int, int)
C:\Program Files (x86)\Arduino\libraries\ICSC/ICSC.h:187: note: void _ICSC::begin(unsigned char, long unsigned int, HardwareSerial
C:\Program Files (x86)\Arduino\libraries\ICSC/ICSC.h:188: note: void _ICSC::begin(unsigned char, long unsigned int, HardwareSerial*, int)
C:\Program Files (x86)\Arduino\libraries\ICSC\ICSC.cpp: In member function 'void _ICSC::begin(unsigned char, long unsigned int, int)':
C:\Program Files (x86)\Arduino\libraries\ICSC\ICSC.cpp:66: error: no matching function for call to 'ICSC::begin(unsigned char&, long unsigned int&, Serial, int&)'
C:\Program Files (x86)\Arduino\libraries\ICSC\ICSC.cpp:64: note: void _ICSC::begin(unsigned char, long unsigned int, int)
Someone knows what might that be?
Greetings
