Problem with processing data from infrared transmission
Hi all
I’m trying to make my one laser tag system. Since I’m not that good in programming, I took an existing code from an instructable project. This was originally designed for an arduino duemillanove, but since the author had a 328-chip on it, there shouldn’t be any compatibility problems.
Hardware:
  • Arduino Uno SMD Rev3
  • Receiver: Board with an IR-receiver, 38kHz frequency (I tried different frequencies). Singnal goes to Pin12 (including pullup resistor)
  • Transmitter: IR-diode, driven by a power NPN-transistor from Pin2
  • Trigger Switch: Pushing connects Pin3 to ground (including pullup resistor)
In the Serial Monitor everything looks fine at first. After startup it shows:
“Startup…
Oscilation time period /2: 9
Pulses: 23
Byte1: 01000001
Byte2: 00100001
Parity: 0
Ready…”
Also the firing is OK in the Monitor, but when a do a “Hit” (IR-pulse to the receiver) then always this error shows up:
“ERROR
sensor: 1… 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2”
The relevant code section is the following:
// Parity Check. Was the data received a valid signal?
    check = 0;
    for(int i = 1; i <= 16; i++) {
      if(received[i] == 1){check = check + 1;}
      if(received[i] == 2){error = 1;}
    // Serial.println(check);
    check = check >> 0 & B1;
    if(check != received[17]){error = 1;}
    if(error == 0){Serial.println("Valid Signal");}
    else{Serial.println("ERROR");}
    if(error == 0){interpritReceived();}
    digitalWrite(hitPin,LOW);
Any help is very much appreciated. Not just by me since many others had the exact same problem, although the author claims the code is working!
LaserTag_Ver1.ino (18.9 KB)
Sorry I didn’t post all of the relevant code.
This is the “receive”-function:
void receiveIR() { // Void checks for an incoming signal and decodes it if it sees one.
  int error = 0;
  if(digitalRead(IRreceivePin) == LOW){    // If the receive pin is low a signal is being received.
    digitalWrite(hitPin,HIGH);
    if(digitalRead(IRreceive2Pin) == LOW){ // Is the incoming signal being received by the head sensors?
      received[0] = 1;
    else{
      received[0] = 0;
    while(digitalRead(IRreceivePin) == LOW){
    for(int i = 1; i <= 17; i++) {                        // Repeats several times to make sure the whole signal has been received
      received[i] = pulseIn(IRreceivePin, LOW, timeOut);  // pulseIn command waits for a pulse and then records its duration in microseconds.
    Serial.print("sensor: ");                            // Prints if it was a head shot or not.
    Serial.print(received[0]);
    Serial.print("...");
    for(int i = 1; i <= 17; i++) {  // Looks at each one of the received pulses
      int receivedTemp[18];
      receivedTemp[i] = 2;
      if(received[i] > (IRpulse - 200) &&  received[i] < (IRpulse + 200)) {receivedTemp[i] = 0;}                      // Works out from the pulse length if it was a data 1 or 0 that was received writes result to receivedTemp string
      if(received[i] > (IRpulse + IRpulse - 200) &&  received[i] < (IRpulse + IRpulse + 200)) {receivedTemp[i] = 1;}  // Works out from the pulse length if it was a data 1 or 0 that was received
      received[i] = 3;                   // Wipes raw received data
      received[i] = receivedTemp[i];     // Inputs interpreted data
      Serial.print(" ");
      Serial.print(received[i]);         // Print interpreted data results
    Serial.println("");                  // New line to tidy up printed results
    check = 0;
and here the “shoot”-function:
void shoot() {
  if(FIRE == 1){ // Has the trigger been pressed?
    Serial.println("FIRE 1");
    sendPulse(IRtransmitPin, 4); // Transmit Header pulse, send pulse subroutine deals with the details
    delayMicroseconds(IRpulse);
    for(int i = 0; i < 8; i++) { // Transmit Byte1
      if(byte1[i] == 1){
        sendPulse(IRtransmitPin, 1);
        //Serial.print("1 ");
      //else{Serial.print("0 ");}
    for(int i = 0; i < 8; i++) { // Transmit Byte2
      if(byte2[i] == 1){
       // Serial.print("1 ");
    if(myParity == 1){ // Parity
    Serial.println("");
    Serial.println("DONE 1");
Any help is very much appreciated!
receiveIR() is NOT a void. It is a function.
Sorry I didn't post all of the relevant code.
If you KNOW that that is now all of the relevant code, then I am sure that you are equally capable of fixing it.
If you are, then posting here was a waste of our time.
If are, then what makes you think you are the expert in determining what is relevant?
