I'm a beginner of Arduino and processing so i have some problems.
Just for information I made an elevator and i need save the data as current over motor and speed, that Arduino read with an encoder, from arduino to a .txt file.
Well, as you can see i just realized a .pde file that save the rpm motor in a .txt file.
The real problem is that I need, also, save the data current in that, or another, file but i don't know how I can do because current is a float.
So what i need to do?
Thank you
PS rpm is an integer
rpm.pde (1.09 KB)
the code is also here:
import processing.serial.*;
Serial port;
PrintWriter output;
int rpmAv;
// Create a new file in the sketch directory
output = createWriter("rpmAv.txt");
// GO FIND THE ARDUINO
println(Serial.list()); // print a list of available serial ports
// choose the number between the [] that is connected to the Arduino
port = new Serial(this, Serial.list()[0], 9600); // make sure Arduino is talking serial at this baud rate
port.bufferUntil('\n'); // set buffer full flag on receipt of carriage return
void serialEvent(Serial port){
String inData = port.readStringUntil('\n');
inData = trim(inData); // cut off white space (carriage return)
rpmAv = int(inData); // convert the string to usable int
void draw() { // Could use void loop() here instead?
output.println(rpmAv); // Write the RPM to the file
void keyPressed() {
output.flush(); // Writes the remaining data to the file
output.close(); // Finishes the file
exit(); // Stops the program
I once made a sample sketch that saves two ';' seperated values per line in a csv file with a timestamp.
The datatype that generated the single fields does not matter, the text representation gets passed.
Serial mySerial;
PrintWriter output;
int lf = 10; // Linefeed in ASCII
printArray(Serial.list());
mySerial = new Serial( this, Serial.list()[3], 115200 );
output = createWriter( "log12.csv" );
mySerial.bufferUntil(lf);
void draw() {
void serialEvent(Serial p) {
String rStr = p.readString();
if ( rStr != null ) {
if (rStr.length() > 2) {
String[] fld = splitTokens(rStr, ";");
if (fld.length>=2) {
output.print(year());
output.print(".");
output.print(month());
output.print(".");
output.print(day() );
output.print("-");
output.print(hour() );
output.print(":");
output.print(minute());
output.print(":");
output.print(second());
output.print("-");
output.print(millis());
output.print(";");
output.print(fld[0]);
output.print(";");
output.println(fld[1]);
void keyPressed() {
Thank You
later i'm gonna try this script.
