Problem with Program: HELP!
Hello,
I am getting strange errors with my program. Here they are.
Scheduler.cpp:17: error: new types may not be defined in a return type
Scheduler.cpp:17: error: two or more data types in declaration of ‘AddTask’
Attached are the files for my program. How can I fix these problems?
Unos_0_1_2.ino (278 Bytes)
Timer.h (1.1 KB)
Timer.cpp (1.03 KB)
Scheduler.h (1.15 KB)
Scheduler.cpp (1.63 KB)
Why are you declaring this in every function?
Scheduler Task;
Do you know about scope and passing variables?
Well, where am I supposed to declare an instance of Scheduler in order to call functions?
Declare it globally.
It seems you need a book on programming to understand how variables work. One of the many things to learn: variables declared within a {} block only exist within that block.
Yes, I know that part about scope. Thanks.
    // This variable is used in Time() and is the amount of time for waiting in milliseconds.
    unsigned long TIME_NEEDED;
We are getting REALLY tired of telling you that all capital letter names are reserved for CONSTANTS. Get with the program or get out of here!
OK. Now I get these errors.
Unos_0_1_2.ino:20: error: multiple definition of `Task’
Scheduler.cpp:19: first defined here
Unos_0_1_2.ino (282 Bytes)
Scheduler.h (1.16 KB)
Scheduler.cpp (1.54 KB)
Timer.h (1.1 KB)
Timer.cpp (1.03 KB)
int Timer::Time(unsigned long TIME_NEEDED)
The value passed to this function is not used. Why does it take an argument?
PaulS,
OK. I fixed that. But what I really wanted to fix was those pesky compiler errors.
Scheduler Task;
This is the last line in Scheduler.h. It needs to be in the .cpp file instead.
I had to add this to the .ino
extern Scheduler Task;
and it compiled fine.
Thank you so much, Delta_G!
