system
November 30, 2010, 9:41pm
1
Hello,
I recently bought an Arduino Uno and tried to make something funny.
I created a program in python that connects to a port and send desired data..
python:
arduino = serial.Serial(portaCOM, 9600, timeout = 1)
... in loop ->
arduino.write(value)
The pde program is going to read the data via usb and trying to set analogWrite(pin, value)'s value.. but here it's the problem..nothing is happening, well i mean i don't know how to correctly set the value...
arduino:
const int ledPin = 11;
byte brightness;
void setup(){
pinMode(ledPin, OUTPUT);
void loop(){
while(Serial.available()){
brightness = Serial.read();
Serial.print(brightness);
analogWrite(ledPin, brightness); //LED doesn't refresh the brightness
delay(10);
can u help me please?
thank you in advance
If you use the serial monitor of the IDE instead of python, does it work?
change the delay(10) in delay(1000) as every string from python may include a \n at the end being a value of 13 which almost will not lighten up the LED.
Can you share the complete code (python part)?
system
November 30, 2010, 10:41pm
3
import wx, serial, time
portaCOM = 'COM5'
class Frame(wx.Frame):
def __init__(self, parent, title):
wx.Frame.__init__(self, None, title=title, size=(285,110))
panel = wx.Panel(self, -1)
self.slider = wx.Slider(
panel, 100, 127, 0, 255, (10, 10), (250, -1),
wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | wx.SL_LABELS
self.slider.SetTickFreq(5, 1)
self.Bind(wx.EVT_SLIDER, self.sliderUpdate)
def sliderUpdate(self, event):
pos = self.slider.GetValue()
arduino.write(pos)
time.sleep(.1)
print arduino.readline()
try:
except:
print "Errore di connessione alla porta seriale"
app = wx.App(False)
frame = Frame(None, "Slider LED")
frame.Show()
app.MainLoop()
Ok I noticed that sending (char(0xff)) it's working , with the serial monitor as well, if I send a random char it's working..now how to do this by python?
system
December 1, 2010, 11:42am
5
You want python to send random characters?
system
December 1, 2010, 1:42pm
6
Random char's in python...
Python
import random
for x in range(0,100): # Do this 100 times
print random.randrange(0,256) # Print a random within 0-255
sleep(0.25) # Wait 1/4 second
You can have it write the random byte to serial instead...
system
December 1, 2010, 4:02pm
7
Thank you to everybody!!! I solved the problem just setting
arduino.write(chr(pos))
and rebuilding the python in an easier and more correct version
