Problem with QTR-1RC digital sensor
ok so here is my problem:
i have managed to get reading from the sensor, i made it so i can read 0 when white and 1 when black
the problem is on the serial monitor i get an extra value on the end of the value which is 8224 and a 0 and i do not know why…
this is my code:
#include <QTRSensors.h>
#define NUM_SENSORS   1     // number of sensors used
#define TIMEOUT       2500  // waits for 2500 microseconds for sensor outputs to go low
#define EMITTER_PIN   2     // emitter is controlled by digital pin 2
QTRSensorsRC qtrrc((unsigned char[]) {3},
  NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
void setup ()
  int i;
  pinMode(13, OUTPUT);
  digitalWrite(13,HIGH);
  for (i=0; i < 400; i++)
  {qtrrc.calibrate();
  digitalWrite(13,LOW);
  for (i=0; i < NUM_SENSORS; i++)
  {Serial.print(qtrrc.calibratedMinimumOn[i]);
  Serial.print('  ');
  for (i=0; i<NUM_SENSORS; i++)
  {Serial.print(qtrrc.calibratedMaximumOn[i]);
  Serial.print('  ');
  unsigned int position = qtrrc.readLine(sensorValues);
  unsigned char i;
  {Serial.print(sensorValues[i]/1000);
  Serial.print('  ');
  Serial.print("    ");
  Serial.println(position);
  delay(250);
and this is what i get on the serial monitor:
any help will be much apreciated …
thanks
please post code between code tags - it is the # button above the smileys
one error
  unsigned char i;
    Serial.print(sensorValues[i]/1000);  //  you forgot the index here
    Serial.print('  ');
  Serial.print("    ");
  delay(250);
oups... yes sorry... done and ... it was because i didn't put it in the code thing that it somehow didn't write the index when i copied... but it is there...
i have also added a second sensor and it still shows me that 8224 .. now it shows me that after the reading from the second sensor as well
anyone else know anything?
