hello, i’m getting mad, i need help.
i’m building this kit but when i reached the receiver fase, i got a big problem, at first a bug with the library, next a bug with “if”, now my radio results not available, this is the code
- File: nRF24l01 Receive Test
- Author: panerqiang@sunfounder.com
- Date: 2015/1/31
- Overview
- This project was written to test nRF24l01 module. If it runs, arduino will
receives data from another transceiver with 2 Analog values from a Joystick
or 2 Potentiometers Displays received values on Serial Monitor. - Request
- FR24 library
- Connections
- nRF24L01 to Arduino
1 GND GND
2 VCC 3V3!! NOT 5V
3 CE D9
4 CSN D10
5 SCK D13
6 MOSI D11
7 MISO D12
8 UNUSED
/* Includes ------------------------------------------------------------------/
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
/ Ports ---------------------------------------------------------------------/
#define CE_PIN 9
#define CSN_PIN 10
/ nRF24l01 ------------------------------------------------------------------/
// NOTE: the “LL” at the end of the constant is “LongLong” type
const uint64_t pipe = 0xE8E8F0F0E1LL; // Define the transmit pipe
RF24 radio(9, 10); // Create a Radio
/ Joystick ------------------------------------------------------------------/
int joystick[2]; // 2 element array holding Joystick readings
- setup function
Serial.println(“nRF24l01 Receiver Starting”);
radio.begin();
radio.setRetries(0, 15);
radio.setPALevel(RF24_PA_HIGH);
radio.openReadingPipe(1, pipe);
radio.startListening();;
- loop function
if ( radio.available() )
// Read the data payload until we’ve received everything
bool done = false;
while (!done)
// Fetch the data payload
done = radio.read( joystick, sizeof(joystick) );
Serial.print("X = “);
Serial.print(joystick[0]);
Serial.print(” Y = ");
Serial.println(joystick[1]);
Serial.println(“No radio available”);
and this is the trasmitter
- File: nRF24l01 Transmit Test
- Date: 2015/1/31
- Overview
reads Analog values on A0, A1 and transmits them over a nRF24L01 Radio Link
to another transceiver. - Request
- FR24 library
- Connections
1 GND GND
2 VCC 3V3!! NOT 5V
3 CE D9
4 CSN D10
5 SCK D13
6 MOSI D11
7 MISO D12
8 UNUSED - Joystick to Arduino
GND GND
VCC 5V
X A0
Y A1
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
#define JOYSTICK_X A0
#define JOYSTICK_Y A1
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
- setup function
radio.begin();
radio.openWritingPipe(pipe);
- loop function
joystick[0] = analogRead (JOYSTICK_X);
joystick[1] = analogRead (JOYSTICK_Y);
radio.write( joystick, sizeof(joystick) );
i hope you could help me… :o
