Hi there i’m facing i probleme to read temperature and altitude in my program. i have a bmp085. i use a library from i2cdev jrowberg.
my programe look like that
while (micros() - loop_timer < 4000);// i did some functions every 4 milliseconds
loop_timer = micros();
me i want to get altitude and temperature with no delay function and every 4milliseconds.
the simple code of jrowberg is
// request temperature
barometer.setControl(BMP085_MODE_TEMPERATURE);
// wait appropriate time for conversion (4.5ms delay)
lastMicros = micros();
while (micros() - lastMicros < barometer.getMeasureDelayMicroseconds());
// read calibrated temperature value in degrees Celsius
temperature = barometer.getTemperatureC();
// request pressure (3x oversampling mode, high detail, 23.5ms delay)
barometer.setControl(BMP085_MODE_PRESSURE_3);
pressure = barometer.getPressure();
altitude = barometer.getAltitude(pressure);
my question is how can i get alltitude and temperature in my loop that run on 4 milliseconds. or how can i delayed the request of temperature and altitude without using delay and that run on 4 milliseconds loop time.
i did lot of tries but i didn’t succed, please help
I read the datasheet and i get altitude and temperature a simple programe with delays. but in my program i can't read those two data. i have not a good programming skill so i wwant some people help me. that all.
I build a quadcopter, and now i’m working on altitude hold. so i have to sample my PID every 4ms. now i want to do an algorithm that get pressur and temperature. i should do in my program a request to get altitude after this request i should wait 25.3 ms then i can get the pressur then i did a request for temperatur then i should wait 4.5 ms then i get temperature. i have to do this whitout delay function. and every 4ms.
my program should look like this
//resquets(temperature)
i wai 4.5 ms
get temperature
seconde loop
request pressur
i wait 25.5 ms
get pressur.
and so on
hi again, i add this in my loop to get altitude now i want to add some lines for temperature but i have no idea how to swith between altitude and temperature.
i want to get altitude first after i get temperature can anyone help me please
unsigned long previousMillis = 0;
int signal_alt = 0;
int i = 0;
if (signal_alt == 0)
barometer.setControl(BMP085_MODE_PRESSURE_3);//request for pressur
signal_alt = 1;
if (currentMillis - previousMillis >= 25.5)
pressure = barometer.getPressure();//after waiting 25.5 ms i get the pressur
signal_alt = 0;
[code]
i would like someone who can help me to add request for temperature that requeir 4.5ms
Thanks
Since you don't want to delay/wait, what you really want is:
if no timer is running (both are zero)
request temperature
start the temperature timer (set it to micros())
if the temperature timer is running and has reached 4.5ms
get temperature
stop the temperature timer (set it to 0)
request pressure
start the pressure timer (set it to micros())
if the pressure timer is running and has reached 25.5ms
get pressure
stop the pressure timer (set it to zero)
First make sure that you are getting T and P values to your arduino and look at the delays within the measurement subroutines.
Presumably you want 250 updates per second for sending your killer robot flying platform on homing-missile-avoidance-loops, split-S near ground level and stuff like that. The BMP085 is, unless set to impaired accuracy, much slower. Nevertheless, you can write an extrapolation routine to provide your flight control subsystems with an estimate of what the altitude should have got to 4, 8, 12, 16, 20, 24 ms after the BMP085 told it a real one. As you'd need three or four consequetive altitude points to get 2nd and 3rd derivatives, the really fancy spline extrapolated h(t) is only good for manouvers in which the control surfaces were still during the forecasting interval and for at least 0.1 seconds before it, as occurs in a loop-the-loop near ground level.
I've never tried testing other inflences on a BMP085 pressure reading but I bet it would detect ground-effect overpressure and tell you that you are some way under when you are in fact twelve inches off the floor. Therefore you might want some other independent height sensor for takeoff height cal, landing, and any really low flying manouvers. I read that ultrasonics pulse timers might get used for that. The expensive way, with a full 3D GPS would be no good for air support of a strike against skynet as the satellites belong to you-know-who.
Back to your question about delays. Do the excercises in examples and go through your bmp085 subroutines to change any blocking delays in there.
Thanks for all you answer some flight controller use temperatur and pressur to do altitude hold. and they works on 3ms loop time.
i read some documentation and they told that we get temperature and pressur to do the altitude hold.
Mr johnwasser i don't understand what do you mean by timer ? could you please explaine more or write me some lines of code thanks. you are great as always.
jone31:
Mr johnwasser i don’t understand what do you mean by timer ? could you please explaine more or write me some lines of code thanks. you are great as always.
Only because I wanted to use the code myself. This code is untested. It might not even compile. Good luck with it.
float CurrentTemperature = 0; // Degrees C
float CurrentPressure = 0; // Pascals
float CurrentAltitude = 0; // Meters
void UpdateAltitude() {
static unsigned long temperatureTimer = 0;
static unsigned long pressureTimer = 0;
// If neither timer is running...
if (temperatureTimer == 0 && pressureTimer == 0) {
// Request a temperature reading
BMP085.setControl(BMP085_MODE_TEMPERATURE);
// Start the temperature timer
temperatureTimer = micros();
// If the temperature timer is running and has reached 4.5 ms
if (temperatureTimer != 0 &&
micros() - temperatureTimer >= 4500UL) {
// Fetch the temperature reading
CurrentTemperature = BMP085.getTemperatureC();
// Stop the temperature timer
// Reqest pressure/altitude reading in high detail mode
// Start the pressure timer
pressureTimer = micros();
// If the pressure timer is running and has reached 25.5 ms
if (pressureTimer != 0 &&
micros() - pressureTimer >= 25500UL) {
// Fetch the pressure and calculate altitude
CurrentPressure = BMP085.getPressure();
CurrentAltitude = BMP085.getAltitude(CurrentPressure);
// Stop the pressure timer
pressureTimer = 0;
jone31:
God bless you Mr johnwasser it's works like a charm.
Thanks
Do you now understand what I meant by "Start the timer (set it to micros())" and "Stop the timer (set it to zero)" and "If neither timer is running"? You can use that trick any time you want to delay an action or create a timed sequence of actions. For longer intervals you could use millis() instead of micros().
