Problem with reading the voltage divider sensor
Hi everyone, I'm a new member here.
I want to find a solution related to voltage sensor readings in my thesis project.
My thesis is about Maximum power point tracking (MPPT) using a single-ended primary-inductor converter (SEPIC), hence need voltage and current sensor to run the algorithm. I use two voltage and current sensors each for the input and output of the converter.
when I want to calibrate the voltage divider sensor on the input side of the converter, I find that the ADC value starts to fluctuate and is unstable when I give the converter a duty cycle of around 40% or above. but strangely this ADC fluctuation does not occur on the output side regardless of the duty cycle value that I give.
I've tried measuring the voltage divider sensor on the input only to see the voltage divided by the multimeter, and I've found that the voltage fluctuates when I activate the converter.
Please help me find a solution to fix it, thanks.
note:
resistor values 10k and 1k (2x I/O)
current sensors ACS712 30A (2x I/O)
input voltage 18V
Ignore Vout and ADC2
what i got
Hello
Do you have to use the am current sensor ?
If yes, than take some time and study the tutorials avaibable and check the given restrictions.
If not, than take some time and read the datasheets if the INA2xx familie sensors.
Off hand I would suspect the input to your converter has more noise than the output. I would suggest you add a 0.1µF capacitor at the instrumentation side of the divider.
I think yes, because I use it on a 100 wp solar panel with specifications like this.
do you have a better sensor recommendation to use on my system?
Hello
Well, my recommadation is to made a selection matrix with design goals vs sensors to find the best sensor for your project.
If you are writing a thesis you should already know that the first time you use an acronym you should show it in full; eg
MPPT or Maximum Power Point Tracking is ...
The single-ended primary-inductor converter (SEPIC)
You have not said what FREQUENCY the SEPIC is using; that will affect the values you need to filter out noise introduced by the SEPIC which is changing the load on the solar panel - and hence its voltage; and also the voltage produced at the output.
  • Like the buck–boost converter, the SEPIC has a pulsating output current. The similar Ćuk converter does not have this disadvantage, but it can only have negative output polarity, unless the isolated Ćuk converter is used.
  • Since the SEPIC converter transfers all its energy via the series capacitor, a capacitor with high capacitance and current handling capability is required.
  • The fourth-order nature of the converter also makes the SEPIC converter difficult to control, making it only suitable for very slow varying applications.
yeah, sorry about that sir.
I use 62.5 kHz switching frequency, with a target output voltage of 24 volts
the electronic components that I use for the filter circuit are, capacitors 470uF/50V (2x), toroid inductors 28,6uH (2x), MUR3060 diode, and IRFP450N mosfet.
Is it like this
test
Thanks for the advice.
Update post, hello everyone I have found the problem causing the voltage sensor reading on my converter. The cause of the problem is the poor grounding quality of the converter so it requires a direct ground from the arduino.
Thanks to everyone who read this post and provided suggestions. :grin:
Yes, Unless you need fast response a filter into the analog pin is always desirable.
