Hi everyone
I'm working on a project where I cast a plaster bust (I have a silicone mold) which gets equipped with capacitive sensors (copper foil) at some spots to make it interactive.
Here's how I do it:
- I brush a thin layer of plaster inside of the silicone mold and let it dry
- Then I glue some round pieces of copper foil (diameter approx. 2.5 cm) onto it and solder a cable to each one
- Then I apply a layer of hot glue
- Then another layer of copper foil (over the whole whole surface of the sensors/hot glue). I then solder a cable onto it (for grounding)
- Then the rest of the plaster, I let it dry, remove the bust, done
So far, so good. What's problematic now is that one of the sensors isn't working.
I did a test with 3 sensors and one doesn't really work. I made 2 videos showing the readings:
- This shows sensors 1 + 2 --> Working well
- This shows sensors 1 + 3 --> It's like slow mo, as if something was stuck. By the way, the code is the same, I just switched cables on a breadboard.
Here's the code:
#include <CapacitiveSensor.h>
//CapacitiveSensor cs_4_2 = CapacitiveSensor(4,2);
CapacitiveSensor cs_4_6 = CapacitiveSensor(4,6);
CapacitiveSensor cs_4_8 = CapacitiveSensor(4,8);
//cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);
cs_4_6.set_CS_AutocaL_Millis(0xFFFFFFFF);
cs_4_8.set_CS_AutocaL_Millis(0xFFFFFFFF);
long start = millis();
//long total1 = cs_4_2.capacitiveSensor(30);
long total2 = cs_4_6.capacitiveSensor(30);
long total3 = cs_4_8.capacitiveSensor(30);
//Serial.println(total1);
//Serial.print("\t");
Serial.print(total2);
Serial.print("\t");
Serial.println(total3);
delay(10);
It would be so awesome if someone has an idea what could be causing this. Is there a short circuit going on or was there a soldering problem?
Thanks and best wishes
