Problem with realy in Arduino Nano
Hi.
I am having trouble trying to get a simple 5V relay to work on an Arduino Nano.
My set up is simple: I connected the pins in the relay as follows: IN to DigitalPin8, GND to Ground and VCC to 5V. The
Nothing fancy, I have not even connected anything to the other end of the realy...... I just expect the relay to click once every second according to the code below, but it is not doing what I expect
These are symptoms that may give extra info:
. The red led on the relay block turns on an off every second although it is not very bright
. If instad of connecting the IN pin to pin8 I connect it directly to 5V, the relay is indeed actuated and teh red LED lightts up at full power
I suspect I may be stumbling upon voltage issues on Pin8. any comments?
I have tried 3 different relays with the same results.
Any hints really appreciated
int relayPinOut = 8;
digitalWrite(relayPinOut, LOW);
Serial.println(" OFF");
digitalWrite(relayPinOut, HIGH);
Serial.println(" ON");
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
In your setup you need to add.
pinMode(relayPinOut,OUTPUT);
This will set your output pin as an output.
Tom... :slight_smile:
Tom. Thanks a lot for your reply! Cheers! :slight_smile:
