Problem with receiving data from 2 devices through i2c
Hello all
I'm trying to read from a MPU6050 and at the same time receive some data from a raspberry pi both over i2c, this is the code I'm using:
#include "I2Cdev.h"
#include "MPU6050.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
int data[4];
int x=0;
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define OUTPUT_READABLE_ACCELGYRO
    accelgyro.initialize();
void receiveData() {
  Wire.begin(0x04);
  while(Wire.available()) {
      if(x==4) { x=0;}
      data[x]=Wire.read();
      x++;
void imu(){
        Wire.begin();
  #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
  #endif
  accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    imu();
    receiveData();
    Serial.print("a/g:\t");
    Serial.print(ax); Serial.print("\t");
    Serial.print(ay); Serial.print("\t");
    Serial.print(az); Serial.print("\t");
    Serial.print(gx); Serial.print("\t");
    Serial.print(gy); Serial.print("\t");
    Serial.print(gz); Serial.print("\t");
    Serial.println(data[1]);
And following is the code I'm using on the raspberry pi:
import smbus
import time
bus = smbus.SMBus(1)
address = 0x04
def writeNumber(a,b,c,d):
    bus.write_i2c_block_data(address, a, [b, c, d])
    return -1
while True:
    try:
        x = raw_input("Enter:")
        x = int(x)
        y = x/10
        z = round(y)
        k = int(z)
        writeNumber(0,k,2,3)
        time.sleep(0.01)
    except KeyboardInterrupt:
        quit()
Values from the IMU are being received but the data sent from RPi dont and I'm kind of new to this.
What am I doing wrong?
The Wire library is not completely multimaster capable and multimaster setups in general are never reliable (at least I never heard of any setup that worked reliable).
The slave part is not implemented correctly. You need to implement onReceive and onRequest events, keep in mind that these are run in interrupt context.
I strongly suggest that you change the interface to the Raspberry Pi. If the connection is short you may use SPI, otherwise UART (maybe over RS-485) might be an option.
